Oil & Fuel kubota 4900 hydraulic fluid problems
/ kubota 4900 hydraulic fluid problems #1
mrelder
massey 1030
kubota 4900 has hydraulic problems. Must warm up for a while before lift works.
Hydraulic fluid dip stick shows a LOT of water.
When I pull the dipstick; milky fluid flows out of it.
Any suggestions where the water is getting in?
I am gonna change the fluid and filter, but I would like to find where the water is getting in there.
Thanks in advance.
mike
/ kubota 4900 hydraulic fluid problems #2
Gear shift boot..........:2cents:
good answer peter 315!
the gear shift boot is defective!
large hole on top of rubber boot
thanks to you
/ kubota 4900 hydraulic fluid problems #5
Your going to change the hyd oil a couple of times (maybe more) to get all the water out......
thank you peter
2012 PETERBILT 367 (A60736)
2012 PETERBILT 367...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
KUBOTA L47 BACKHOE (A62129)
KUBOTA L47 BACKHOE...
