Comparison Kubota 4760
/ Kubota 4760 #1
rstod
Meriden, New Hampshire
kubota 4610, kubota 4200, John deere 455, exmark 72" zeroturn mower, takeuchi tb260 excavator
Thinking of replacing my Kubota 4610 (cab) with a new Kubota 4760 ( cab). Can anyone offer any advice on the 4760? I plow snow and handle palletized firewood during the winter ......and my wife uses it all summer for her gardening projects. I have been out of the tractor market, pretty much, since buying the 4610 about 20 yrs ago. Any thoughts/views would be appreciated.
/ Kubota 4760 #2
I have the smallest Kubota Grand L, an L3560.
The HST+ transmission is wonderful.
I am 73 years old. I appreciate the waist level fuel entrance, so you fuel standing on the ground.
I've owned my L3560 since January 2013. Well worth the money.
The L4760 has enough power to compensate for the 650 pounds of cab weight.
Few would not load load the tires of an L4760 cab tractor. The cab provides enough rear tire weight for traction.
/ Kubota 4760
thanks for that info, Jeff. I haven't compared the specs closely...assuming they are similar...with the 4760 being superior. I do like the idea of the easy access fueling too....being 71, myself, things like this matter. The HST is great ( currently have it on the 4610 ) and makes it possible for my wife to operate the tractor...with ease. I will load the rears and run chains on the front....as I have been doing with the 4610....really need it for traction for plowing snow. The 4670 has a roomier cab w/better access thru doors....also something this 6'2 old man is looking forward to.
/ Kubota 4760 #4
I plow a wide variety of rural driveways with my L4060. With fluid filled rears and grooved R4's I have yet to need to use chains.
My previous L3410 open station was considerably lighter, and showed it while plowing.
The transmission is a giant leap forward from the L10 series machines.
/ Kubota 4760 #5
I have owned my 5460 for about 1.5 years. The 5460 is the same tractor as the 4760 only a turbo is added. I have been very pleased overall with the tractor. I wrote a long review of the tractor which you can find if you look for threads I started. The feature I like most is the ability to switch on the fly between hi and low within each range. Also I don’t know if you are considering a cab but the Grand L cab is nice. Also I really like the fact that the hood and fenders are steel like a tractor should be.
I actually wanted a 4760 but the dealer had a 5460 on the lot and gave me a good price.
/ Kubota 4760 #6
The HST on the 4610 is nothing like the HST+ on the 40 and 60 series Grand L tractors. There's a lever near the steering wheel that acts like a high and low range for each of the 3 gears. You can shift it at any time, even without letting off the HST pedal. I rarely have to shift into low or high gear.
/ Kubota 4760
I have heard about that 'shift on the fly' and it sounds great. with my 4610, I often use the 3 ranges and, of course, have to be completely stopped to shift ( and Then it isn't what I would call a smooth operation.....especially on a slope ). So really looking forward to having That feature.
/ Kubota 4760
I Have plowed w/o the chains...and the traction is ok for the most part...but I have a cpl small slopes to deal with and the chains make all the difference. being only the fronts it's an easy install..so no big deal.
/ Kubota 4760
Does anyone know what the model JD would be comparable to the 4760 / cab ? and how it stacks up performance and price-wise?
/ Kubota 4760 #10
You would need to look at either the JD 4044R or the 4052R depending on if you want to go on the low or high side of the Kubota L4760.
ALL of these tractors are very nice machines. :thumbsup:
/ Kubota 4760 #11
I have a 2011 5240 great tractor added steps and air ride seat bought it new in 2012. The width of this one one was better than JD at the time. Would be happy to answer any questions you might have
2019 Nissan Sentra Passenger Car, VIN # 3N1AB7AP9KY318147 (A61574)
2019 Nissan Sentra...
King Kutter II Tiller for sale.
King Kutter II...
2008 GALYEAN 120 BBL ACID TRAILER (A63569)
2008 GALYEAN 120...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
