Kubota 26L engine
   / Kubota 26L engine #1
2458n
Veteran Member
Does this engine have any history? Good or Bad please.
   / Kubota 26L engine #2
Kubota engines start with a Z for 2 cylinders, a D for 3 cyls., V for 4, F for 5, and S for 6 cylinders, followed by an approx cc displacement. Typically this number is stamped on the top of the block near the injection pump on older engines and on a pad under the exhaust manifold on newer engines.
Brian
   / Kubota 26L engine
Thank you Brian for the correction. The tractor has a 6 in it. the machine is a M model. M4500DT with 3400 hours. Anything to look out for?
   / Kubota 26L engine #4
I will assume then that it is an S2600. There isn't anything out of the ordinary I would look for. 3000 hrs is not that many if it was reasonably cared for. I'd look for any exhaust smoking and excessive blow-by, along with how easily it starts.
   / Kubota 26L engine
Again thank you for your input. How can they talk about outlawing gambling on line. Anyone looking for equipment on line is certainly in that same area.
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
