Kubota 13901
/ Kubota 13901 #1
vadim2k
Kubota 13901
Hello all,
Fairly new owner and have been having some issues. Was running it today and it died on me mid run. The fuel filter was recently changed and I can't seem to figure it out. Turns on runs for 30s to a min then dies. Battery was recently changed out but it was changed to an autozone battery. Might need to get one from kubota. Please help.
/ Kubota 13901 #2
Did the problem present itself after the fuel filter change? Sounds like it could be a fuel/air issue.
/ Kubota 13901
It seems to have started 2 months after the filter change
/ Kubota 13901 #5
Link to fuel system help in the last post
/ Kubota 13901 #6
More information you can give the better.... How old is your L3901? Did you buy it new or used? How old is your fuel in the tank? (did you drive it a lot before this problem?) What I'm getting at, could you have algae in the tank? (it could be blocking your outlet)
You could also have a leaf or debris in the tank blocking the outlet...
How does the engine die? Cuts out quickly (like a safety switch killed the engine?) or does the engine, slowly dies (fuel starved?) Does it start right back up or do you have to let it sit for a while?
Are you moving around in the seat when it dies? or when you are turning the tractor?
(INOP) 1986 JOHN DEERE 310C BACKHOE (A59823)
(INOP) 1986 JOHN...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
