KT17 No Spark
/ KT17 No Spark #1
Brockwaykid
Granville NY
John Deere 317 (KT17 SII)
Hey everyone, I am having trouble with my 317. I have tested the battery, and it tests fine. I also tested the positive terminal of the coil for 12v and it is good. I found a diagram for testing a Kohler coil, but I've only been able to get one test done. I put a multimeter on the positive and negative terminals of the coil with the key off and found a resistance of 5.3 ohms. This made me feel good since the spec was between 4 and 8 ohms. The next test was from the positive terminal to the "tower" (I'm not real sure what it is). I think it is the larger terminal for one of the plug wires? Anyhow, I got open line when it should have been between 7-12000 ohms. Not really sure of what else to do. Any suggestions? Thanks
/ KT17 No Spark #2
Did you check the points?
/ KT17 No Spark
yes, they were arcing, and i adjusted them to .020 and cleaned them with a dollar bill.
/ KT17 No Spark #4
Cleaning may not do it. If the points are badly pitted, they will not work right. If they are not pitted to bad, you can file them flat and then readjust the gap.
If still not getting spark, you may want to replace the condenser.
Richard
/ KT17 No Spark
Richard
I just put the points on not quite 2 years ago. I pulled them off today and they arent very dirty or pitted at all. they look pretty clean. I have been reading forums alot today. The consensus seems to be the condenser. I replaced that at the same time as the points and coil. Strange.
Thanks for the advice!
/ KT17 No Spark
It ended up being a bad connection at the PTO switch. That was aggrevating! Thanks for your help!
/ KT17 No Spark #7
Glad you got it figured out. With all the safety switches on the newer tractors, it really does make trouble shooting more complicated.
Good job!!
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
2022 EZ-GO ELITE...
2025 48in. Farm Jack (A64553)
2025 48in. Farm...
FORD 5 BOTTOM PLOW (A64278)
FORD 5 BOTTOM PLOW...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
