Koyker cylinder piston replacement problem
/ Koyker cylinder piston replacement problem #1
rstuart
I have a Koyker 140 FEL that I am trying to replace a piston in one of the hydraulic cylinders. I was only able to remove the old piston by unscrewing it over the threaded portion using a pipe wrench. When I tried to install the new piston I ran into same problem. The only way to get it started on is to screw its onto the threads on the end. The shaft cuts threads into the aluminum piston but was not able to get it all the way on. I ended up ruining the new piston also. Any idea how to get the piston over the end of the shaft? Will cooling the shaft cause it to contract enough to make the piston fit?
/ Koyker cylinder piston replacement problem #2
Really and truly, if the job was mine to do I'd just take it to the local hydraulic shop.
/ Koyker cylinder piston replacement problem #3
Does that piston have a blind hole in the side of it??
/ Koyker cylinder piston replacement problem #4
Pictures would help.
/ Koyker cylinder piston replacement problem #5
Ditto photos are worth many words
/ Koyker cylinder piston replacement problem #6
Drill a couple of holes in one of the faces and use a spanner wrench to install it.
Wacker Neuson AR14H (A60462)
Wacker Neuson...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
SUPER C PNEUMATIC GUILLOTINE SAW (A64281)
SUPER C PNEUMATIC...
1995 John Deere 7400 (A60462)
1995 John Deere...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
