Koyker cylinder piston replacement problem
/ Koyker cylinder piston replacement problem #1
rstuart
I have a Koyker 140 FEL that I am trying to replace a piston in one of the hydraulic cylinders. I was only able to remove the old piston by unscrewing it over the threaded portion using a pipe wrench. When I tried to install the new piston I ran into same problem. The only way to get it started on is to screw its onto the threads on the end. The shaft cuts threads into the aluminum piston but was not able to get it all the way on. I ended up ruining the new piston also. Any idea how to get the piston over the end of the shaft? Will cooling the shaft cause it to contract enough to make the piston fit?
/ Koyker cylinder piston replacement problem #2
Really and truly, if the job was mine to do I'd just take it to the local hydraulic shop.
/ Koyker cylinder piston replacement problem #3
Does that piston have a blind hole in the side of it??
/ Koyker cylinder piston replacement problem #4
Pictures would help.
/ Koyker cylinder piston replacement problem #5
Ditto photos are worth many words
/ Koyker cylinder piston replacement problem #6
Drill a couple of holes in one of the faces and use a spanner wrench to install it.
1992 CHEVY 1500 CUSTOM (A65643)
1992 CHEVY 1500...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
Stout Buckets HD72-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
(1) HD 24ft Free...
Moffet Forklift (A65579)
Moffet Forklift...
