Komatsu D20A Steering clutches stuck
   / Komatsu D20A Steering clutches stuck #1
Sidman
Komatsu D20 A
Does anyone know what the 2 solenoids on top of the steering pump do and how to check if they are the problem. I've tried everything else.
   / Komatsu D20A Steering clutches stuck #2
Best I recall there are no solenoids on the pump but slave cylinders on the steering actuators, I believe those are dry clutches and if it’s sat any length of time they are probably frozen/rusted from moisture.
Thanks for getting back to me. It sat for 7 years under roof. I was hoping not to tear into the clutches. I was getting oil to the slave cylinders.
   / Komatsu D20A Steering clutches stuck #4
If the actuators are working and you have room you could try running the machine back and forth or under load while steering one way or the other, may jar it loose depending on how bad it is, dry clutches can indeed be a pain, good luck with it.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53472)
2022 NEW HOLLAND...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
2009 VOLVO VNM DAY CAB (A52576)
2009 VOLVO VNM DAY...
