Komatsu D20A Steering clutches stuck
   / Komatsu D20A Steering clutches stuck #1
Sidman
Komatsu D20 A
Does anyone know what the 2 solenoids on top of the steering pump do and how to check if they are the problem. I've tried everything else.
   / Komatsu D20A Steering clutches stuck #2
Best I recall there are no solenoids on the pump but slave cylinders on the steering actuators, I believe those are dry clutches and if it’s sat any length of time they are probably frozen/rusted from moisture.
Thanks for getting back to me. It sat for 7 years under roof. I was hoping not to tear into the clutches. I was getting oil to the slave cylinders.
   / Komatsu D20A Steering clutches stuck #4
If the actuators are working and you have room you could try running the machine back and forth or under load while steering one way or the other, may jar it loose depending on how bad it is, dry clutches can indeed be a pain, good luck with it.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
JOHN DEERE HX14 LOT NUMBER 266 (A53084)
JOHN DEERE HX14...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
