Komatsu D20A-6 ?
/ Komatsu D20A-6 ?
Just went through the entire thread. That's a neat dozer you have there! Really nice and compact.
You have been doing an amazing job restoring the machine.
Thanks for bringing the thread up with an update.
I love the way it looks with the rubber tracks!
I had this small 1962 Italian Crawler tractor with 26 HP that I restored from top to bottom and I've always wanted to replace the tracks with rubber ones but ended up trading the tractor.
Thank you for your kind comments, I sure would like to see what your '62 Italian crawler looked like before you gave it up, I'm sure whoever snatched it up must very much appreciates your restoration work.
/ Komatsu D20A-6 ? #162
Sure. Here it is. 28HP, 2 cylinder air cooled beast.
How it looked before with some of the nasty stuff I've found:
And after:
By the way, I also made a blade for it, which ended going on the big brother of this tractor, which was a 1964 39HP, 3 cylinder that I also sold.
/ Komatsu D20A-6 ?
Why not hang some drop cloths and paint inside? Fire off the salamander afterwards to help the dry time. Maybe break out the redneck powder coating stuff again :D. I missed the switch to rubber track, what do you think of them?
Howdy there ddbackhoe, - amazing you saw and remember my redneck powder coating technique! A procedure I should have copyrighted ;)
"Fire off the salamander afterwards to help the dry time." You do realize that sucker burns kerosene at the rate of about 2 gallons an hour? Have you checked the price of Kerosene :eek: about $ 6.50 a gallon in my neck of the woods. Electric heater for me was the way to go. We have an 8 Kw solar system so my electric power is "free"
Rubber tracks - yes my chip and seal drive and yard really appreciate those rubber tracks. There were installed shortly after the construction of my man cave "barn" shop so it can crawl over the chip and seal and onto the concrete slab to keep it cozy in the shop when its resting. Rubber tracks work good, however for working in mixed rock / dirt I would prefer the old steel tracks. Wish there was some sort of way to have "quick attach tracks" to switch between steel and rubber tracks. :cool:
/ Komatsu D20A-6 ?
ptsg -
WOW what a nice looking vintage crawler, you did an amazing restoration job, congratulations. It belongs in a museum for all to enjoy. Nice work.
:thumbsup:
/ Komatsu D20A-6 ? #165
Thank you sir!
Forgot to mention that I've never finished the hood. It was full of dents, needed to be painted and the grill was also a bit smashed.
Actually, while I sold the 3 cylinder crawler to a English gentleman, I traded this tractor and a Kubota B7000 for a new tractor, so sadly this crawler sat outside under the weather for about a year and a half before the dealer finally put it under a shed. It was already getting all rusty again.
/ Komatsu D20A-6 ?
Setting here in the SLC airport waiting for my flight back to ABQ. Got some time to document the exhaust system restoration with some pics, the airport WiFi is not not that great so will do my best.
Now onto the muffler a.k.a smoke stack repair. A while back I noticed chunks of what looked like fiberglass puffing out every once in a while and an exhaust leak under the hood making everything black with soot. That leak under the hood was especially noticeable when first started in the cold. So I decided something needed to be done. Removed the stack and gutted it out, it was just raw ceramic or glass fiber rolled up and falling apart, nothing to keep it in place or collapsing potentially choking the exhaust flow. And a real bad seal to the spark arrestor canister bolted directly to the exhaust manifold. I went to 4 muffler shops and two parts stores coming up empty handed. Finally, I found the actual wholesale distributor of every muffler and auto shop and parts store in town. He fixed me right up with a Thrush Glass pack blank Its 4 diameter, 18 long with 2.25 inlet and outlet. A near perfect fit.
Links to what I found at the wholesale distributor:
Thrush Glasspack Mufflers 24431 - Free Shipping on Orders Over $99 at Summit Racing
Dynomax 24431: Glasspack Muffler Blank In/Out: 2.25" | JEGS
/ Komatsu D20A-6 ?
After some test fits with the hood installed, and the smoke stack slipped over the new muffler core it was determined the primary muffler extension tube needs to be shortened by 1
/ Komatsu D20A-6 ?
Need a means of sealing the two mufflers together without welds or clamps so the two mufflers are not rigidly connected. There needs to be some flex between the engine and hood mounted smoke stack. And it needs to be easily removed for maintenance access. Decided to use some high density high temp ceramic wool used in forges.
/ Komatsu D20A-6 ?
Put the hood back on, seems to be a good gas tight seal from muffler to hood extension tube. Ready to slip the stack over the new muffler. But first the old smoke stack got a good sanding. What a shame sanding out all that lovely rusty patina. Then it was heated up a bit with the salamander a.k.a kerosene jet engine burner before painting with high temperature flat black stove paint that has a 2000* rating.
Done now for the real test, what is it going to sound like? Hopefully purr like a cat (pun intended)
/ Komatsu D20A-6 ? #170
No sir, you are mistaken. I very much enjoy the stuff you’ve shared here. Ive learned a lot over time with the help of guys like you, Rob (3RRL) and wroughtn_harv. It may seem like little stuff, but the marks people like you all leave are often bigger than anyone can measure.
https://www.tractorbynet.com/forums...0-rotating-back-blade-project.html?highlight=
/ Komatsu D20A-6 ? #171
Im new to the forum. I have enjoyed so much of this thread. Very educational for me. Dont want to offend anyone and hope no one takes it the wrong way I’m only seeking some help. I’m not allowed to post yet as I am new to forum so I’ll get to the point. I’m the proud owner of a d20a-6. My tilt cylinder is leaking pretty bad and Two lift cylinders aren’t looking to great either. So I have decided to repack all five cylinders and I am hoping for advice and if anyone has a part number or cross reference for these cylinders. I’ve called around some hydraulic repair shops and it’s pretty expensive at 75 per hour with an average of hour and a half per cylinder barring any trouble. Not saying it isn’t worth it, it is of course, but it’s expensive for me. So I’m gonna hopefully learn how to do this myself. I’ll be happy to share my endeavors would love to contribute to this thread in a positive way for others. As has been done for me. Thanks and best wishes everyone.
/ Komatsu D20A-6 ? #172
Hey guys, I need to re-pack the cylinders on my D21A and I'm looking for the best way to identify the model and locate the serial number. I think it's a D21A-6, but not sure how to confirm. I've located serial numbers for the transmission, hydraulic valve assy, fuel pump, etc, but for the life of me, I cannot locate the s/n for the machine itself. I think it may be covered by layers of paint, but I'm not sure. Would it be possible for one of you owners to tell me the exact location of your serial number, and possibly shoot a photo of it for me? I've searched and searched. Thank you so much!
/ Komatsu D20A-6 ? #173
Can you provide pictures of what hydraulic lines you tapped into for your remote on the back of the dozer, I got a ripper all set up and for over a month I cant figure out how to make it work, I just dont understand or im using the wrong parts im at a total loss, if you can help I really appreiciated George krackerjack9@sbcglobal.net
/ Komatsu D20A-6 ?
George,
Need to install a new double action valve between the pump and OEM blade valve. Remove the hose and hard line from the pump output all the way to the input of the blade valve. Install a new double action valve. Get a new hose made to connect from the pump output then into the input of the new valve. Then get a new hose made from the new valve back to the input of the blade valve. Basically all you need to do is put the new valve in series with the blade valve. In other words - Output of pump to new valve, output of new valve to input of blade valve. It's a simple in series hydraulic circuit. You will have to remove the floor plate, seat plate and seat riser plate to access to the blade valve hydraulic input fitting , and to remove the hard tube access to remove the valve input fitting really tight, but doable.
Why are there 6 hoses connected to what looks like an electric solenoid operated valve? normally 4 hoses, in, out and the two cylinder ports.
BTW the ripper construction looks really great. Nice work! Is it all home made? if not please share the source for the parts you used.
/ Komatsu D20A-6 ? #175
Thanks for all the input and advice - I made a counter offer, it was accepted so we closed the deal.
Lots have happened since I took delivery - here is an update:
The biggest concern I had with the purchase of this machine was that it would not turn right when you pulled the right steering break lever. I read over the manuals I got and discovered a simple adjustment for the steering breaks. So I pulled off two bolts removed a small cover, tightened up the adjustment bolt a few turns and Shazam! The steering now works perfect ! :D
Here is a picture of my "new" (dirt cheap - used) Dozer at it's new home:
After making the break adjustments to both sides to make them even, I tested out the steering, here is a video of it doing a figure 8. The dozer is amazing, I have never driven or operated a dozer before. It will now turn on a dime:
I will need to drain all the fluids and replace the oil & fuel filters. I think this thing uses about 25 gallons of oil in various places :eek: I also need to reverse the cutting edge on the blade. After that, I think it will be ready to go. Oh need to set the valve lash - I doubt this has had any of the required scheduled maintenance.
Engine-----------------8 liters 15W40
Clutch case---------- 6 liters 10W
Transmission case 16.5 liters 30W
Hydraulic reservoir 33 liters
Final sprocket drives Left & right 12 liters ea (24 total)10W
Total 87.5 L or 23 gallons of various oils.
Fuel tank 60 liters (15.8 gallons)
All in all, this was a smoking deal, and I am fortunate to have found this little machine. I will need to practice on flat land so that I can develop skills in operating it safely and efficiently. The purpose of all this is to use it to cut a road to access the other 3/4 of my property.
Larry
Final drives should be 30wt not 10wt, about 2 gallons each
/ Komatsu D20A-6 ? #176
the 6 lines, are one in and out for up and down for each side so thats 4 then other two are to the ripper up and down thats 6
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
iDrive TDS-2010H...
2006 Volvo VNM S/A Day Cab Truck Tractor (A61568)
2006 Volvo VNM S/A...
2018 Ford AWD Explorer SUV (A61569)
2018 Ford AWD...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
