Kohler Kehein Carb Cap
   / Kohler Kehein Carb Cap #1
GTSRider
Cub Cadet 3000
I mistakenly tapped out the cap on my carb today ... thinking there was an
Idle needle adjustment behind it, but it was a jet, and now gas is leaking from it.
I went online and it appears this cap is not available.... anyone have any ideas ?
There doesn't seem to be much pressure at this point so I loaded a gas sealer in the hole for a possible temp fix.
You'd think this 10 cent cap would be available somewhere ....
other than buying a new carb !
Pete
Oddly enough.... the parts diagrams show the idle needle and not the cap
I have.... may have been an odd model Keihin.
   / Kohler Kehein Carb Cap #3
Welch plugs for Keihin carbs are impossible to find. I've searched several times for them. Harley Davidson uses Keihin carbs and sometimes you can find the right size from a dealer if they're willing to look for you but I normally just end up making one and sealing it in.
So ..there ya go...they don't make a 10 cent replacement plug ?
Wow... I really got myself in deep on this one.... any thoughts ?
Pete
Anyone in the USA ?
Found these guys.... but how do I find the size of the plug ?
One step forward 3 steps backward.....
found plug hiding under carb..... but not a plug at all...but a brass ball.
put a dab of sealer on it , and tapped it back in place.
But here's the problem...which I will post in new thread.
Engine is running super rich... what's up with this **** thing ?
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
