kohler engine
/ kohler engine #1
rfambs
I am rebuilding my 14 hp kohler k321, I got new piston, rings, had it bored, and crank only 1 thousands under so going to use it and rod ok.
my question is the counter balances (2) are loose and to replace them is another $160.00 DOES ANYONE KNOW IF IT WOULD RUN OK WITHOUT THEM, I DONT SEE ANY REASON I COULDNT JUST YANK EM OUT . I ONLY USE THIS MOWER TO PLOW SNOW LIKE 11 TIMES A YR. ANY HELP IS APPRECIATED
/ kohler engine #2
MAny have removed the balancers from the K series Kohlers with good success.
/ kohler engine #3
If I am thinking correctly.. won't removing weight from the crankshaft make the motor have less torque.
/ kohler engine #4
I'd ask about this on IHregistry.com. The balance stuff was there to make the motor run more smoothly when they used to mount the engine directly to the frame before they start using those rubber mounts. I think you may get more opinion from people who are involved with vintage CCs.
/ kohler engine #5
The counter balance 'weights' wont offer any inertial force at all like a lighter/smaller flywheel would take away. Theoretically, taking another moving part out there should zap less power from the engine.
Joel
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
17395SFL (A61568)
17395SFL (A61568)
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
