Kohler Engine Trouble
/ Kohler Engine Trouble #1
Mike Pa
Exmark Lazer Z
Good morning!
Was looking for some advice on a Kohler 27 HP Commercial engine.
Symptoms:
-Using 1/2 Qt of oil in two hours and fouling the plug on the #1 cylinder.
Repairs:
-Pulled the head and found a burnt and broken exhaust valve. Replaced the exhaust valve, head gasket and all the breather components.
The engine is still fouling the plug a bit and there is still excessive crankcase pressure?
Thanks!
/ Kohler Engine Trouble #2
Possibly broken or Stuck rings.
/ Kohler Engine Trouble #3
How did the piston and cylinder look? Also, check valve guide and seal.
Jim
/ Kohler Engine Trouble #5
In the other thread, you said something about not having much play in the valve guide. I think that you shouldn't have any play. With lubricant applied to the valve stem, I would expect no lateral movement.
Jim
Thank you all for your responses. A few notes on your comments:
-The play in the guide was barely noticeable, just a very minor amount with no visble damage to the guide
-My dealer did a leak down test and said all ranges were normal so they chaged all the breather components.
-The piston head was loaded with carbon that we removed, but otherwise in good shape
/ Kohler Engine Trouble #7
If the head was full of carbon, the rings may be that way too.
Quick question: which head is #1 and which is #2?
/ Kohler Engine Trouble #8
That's exactly what I was thinking regarding the carbon. A good dose of Sea Foam or two should be just what the doctor ordered for cleaning up that carbon.:thumbsup:
Jim
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
