Kohler Engine Trouble
/ Kohler Engine Trouble #1
Mike Pa
Exmark Lazer Z
Good morning!
Was looking for some advice on a Kohler 27 HP Commercial engine.
Symptoms:
-Using 1/2 Qt of oil in two hours and fouling the plug on the #1 cylinder.
Repairs:
-Pulled the head and found a burnt and broken exhaust valve. Replaced the exhaust valve, head gasket and all the breather components.
The engine is still fouling the plug a bit and there is still excessive crankcase pressure?
Thanks!
/ Kohler Engine Trouble #2
Possibly broken or Stuck rings.
/ Kohler Engine Trouble #3
How did the piston and cylinder look? Also, check valve guide and seal.
Jim
/ Kohler Engine Trouble #5
In the other thread, you said something about not having much play in the valve guide. I think that you shouldn't have any play. With lubricant applied to the valve stem, I would expect no lateral movement.
Jim
Thank you all for your responses. A few notes on your comments:
-The play in the guide was barely noticeable, just a very minor amount with no visble damage to the guide
-My dealer did a leak down test and said all ranges were normal so they chaged all the breather components.
-The piston head was loaded with carbon that we removed, but otherwise in good shape
/ Kohler Engine Trouble #7
If the head was full of carbon, the rings may be that way too.
Quick question: which head is #1 and which is #2?
/ Kohler Engine Trouble #8
That's exactly what I was thinking regarding the carbon. A good dose of Sea Foam or two should be just what the doctor ordered for cleaning up that carbon.:thumbsup:
Jim
207282 (A52708)
207282 (A52708)
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
