Kohler Engine Trouble
   / Kohler Engine Trouble #1
Mike Pa
Exmark Lazer Z
Good morning!
Was looking for some advice on a Kohler 27 HP Commercial engine.
Symptoms:
-Using 1/2 Qt of oil in two hours and fouling the plug on the #1 cylinder.
Repairs:
-Pulled the head and found a burnt and broken exhaust valve. Replaced the exhaust valve, head gasket and all the breather components.
The engine is still fouling the plug a bit and there is still excessive crankcase pressure?
Thanks!
   / Kohler Engine Trouble #2
Possibly broken or Stuck rings.
   / Kohler Engine Trouble #3
How did the piston and cylinder look? Also, check valve guide and seal.
Jim
   / Kohler Engine Trouble #4
X2 try doing a leakdown test if you have the equip if not most of the dealers have them and should not charge too much to do it for you
Jon
   / Kohler Engine Trouble #5
In the other thread, you said something about not having much play in the valve guide. I think that you shouldn't have any play. With lubricant applied to the valve stem, I would expect no lateral movement.
Jim
Thank you all for your responses. A few notes on your comments:
-The play in the guide was barely noticeable, just a very minor amount with no visble damage to the guide
-My dealer did a leak down test and said all ranges were normal so they chaged all the breather components.
-The piston head was loaded with carbon that we removed, but otherwise in good shape
   / Kohler Engine Trouble #7
If the head was full of carbon, the rings may be that way too.
Quick question: which head is #1 and which is #2?
   / Kohler Engine Trouble #8
That's exactly what I was thinking regarding the carbon. A good dose of Sea Foam or two should be just what the doctor ordered for cleaning up that carbon.:thumbsup:
Jim
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
