Kohler engine question
   / Kohler engine question #1
Hoosier_Daddy
Platinum Member
Indiana
New BX2200 4-3-02 (traded 6-08) new B2620 06-08
I have a 20 hp Kohler that has decided to ruff ruff and dump gas into the oil..
Is that due to the needle valve in the float tank sticking?
Thanks,
Tom
   / Kohler engine question #2
That might do it but it would also help to know what series of a Kohler it is.
   / Kohler engine question #3
Does it have a fuel pump?
If that diaphragm lets go it will dump fuel in to the oil too.
that is my bet
tom
It is a Magnum M20
   / Kohler engine question #5
you might want to check and see if the crankcase breather tube is clogged. I've noted similar issues with a Briggs and a clogged tube.
   / Kohler engine question #7
if you are talking about the needle valve sticking in the float tank, ie., the float sticking in the carb. yes check it. If it is stuck in the down position, where it lets fuel into the carb. it would definately dump the gas in oil. zman
   / Kohler engine question #8
If you think it is the mechanical fuel pump, take it off and work the lever and see if fuel comes out anywhere except the fuel pump outlet. If you think the needle float valve is sticking, clean it or replace the needle valve, then install a fuel shut off valve.
I will check out all that you folks have advised.. For now, I put a shut off in the fuel line....... Seems to be working...
Thanks to all of you,
Tom
   / Kohler engine question #10
I did lose the mechanical fuel pump on my Kohler Command 20 hp at about 250 hours. There are parts in there that are "staked" to retain them, and if enough metal isn't displaced, they fail. Mine runs right off a valve stem so it sure gets a workout.
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A52377)
2019 Chevrolet...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
Ford Tractor (A50120)
2001 Ford F150 (A50121)
2001 Ford F150...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
