Kohler CH25S parts manual and/or exhaust bracket bolt
   / Kohler CH25S parts manual and/or exhaust bracket bolt #1
macindude
Bronze Member
Hubertus, WI
Simplicity Legacy
Hi all,
Does anyone have a parts manual for the Kohler 25hp on the Legacy? (CH25S-68583) I can't find one online, there's just a bunch of parts sites and none of them list the part I need which is just a simple bolt that I need the size of. It goes into the block so I can't take it to the store and try a bunch either...
FWIW, it's the two bolts that hold the exhaust bracket. #6 on the Exhaust Group page. It'd be great if someone could tell me the size, even better if you can hook me up with a parts manual so that I can find the next one on my own. FWIW, it's bigger than a 3/8" bolt from my hardware stash...
Thanks!!!
   / Kohler CH25S parts manual and/or exhaust bracket bolt #2
The muffler may of come suppled by Simplicity not Kohler. so you will need the parts manual for the tractor.. Should have a 7 digit model number on a tag that will allow parts lookup for the tractor.
Odd. The Simplicity parts manual shows it but specifies a 3/8-16 x 5/8”. I took another 3/8-16 bolt and tried it and I’m able to just slide it in. Inner diameter of threads measured with calipers at 3/8” so it’s got to be slightly bigger somehow.
   / Kohler CH25S parts manual and/or exhaust bracket bolt #4
Looks like it could be M-839020-S M8X1.25X20 That is from the muffler kit for the CH25
Well, the immediate problem is solved. The 3/8 bolt Is for older ones than my 1997/8. The correct bolt is 7/16-14x1” per the tractor’s parts manual.
I still wish I had a parts manual for the engine.
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
CAT BUCKET W/QUICK COUPLER ATTACHMENT (A53843)
CAT BUCKET W/QUICK...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
