kohler blowing oil
   / kohler blowing oil #1
dp5069
western Wisconsin
wheelhorses 702 503 854 L-157 CHARGER-9 CHARGER V8 C- 81 1948 8N FORD
I have a 8hp kohler that when it warms up starts to blow oil out of the breather is this a broken ring, or a valve problem? It seems to be buiding up pressure in the crankcase for some reason! thanks in advance! /forums/images/graemlins/confused.gif
   / kohler blowing oil #2
dp509,
That sounds like you called it right, a broken oil control ring.
It wouldn't take to much to check it. Piston and rings shouldn't cost too much.
Chad
   / kohler blowing oil #3
The crankcase breather may be incorrectly installed or defective. I can't remember how it is but they will do this if the breather is not right.
   / kohler blowing oil #4
Ditto on the crankcase breather....If it is malfunctioning your crankcase loses the vacuum it creates to keep the oil in. In most cases they are just gummed up.
   / kohler blowing oil #5
My 12 horse Kohler was blowing oil, and the problem was the crankcase breather. The breather on mine is a metal box with spring loaded valve in it. The box also has a drain hole in it. A previous owner had removed the breather and put it back in with the drain hole up. The breather would fill with oil and couldn't drain. /forums/images/graemlins/tongue.gif
   / kohler blowing oil #6
Thats it gspig, I could not remember up or down. You got it.
Sharpsburg huh, I live just east of Winchester. Howdy.
2010 L3V Electric cart (A51694)
2010 L3V Electric...
Pair 2 new 8' pallet fork extensions (A53421)
Pair 2 new 8'...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2015 Ford F-450 Flatbed Truck (A51691)
2015 Ford F-450...
2001 MACK CH613 KILL TRUCK BOBTAIL (A53843)
2001 MACK CH613...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
