kohler blowing oil
   / kohler blowing oil #1
dp5069
western Wisconsin
wheelhorses 702 503 854 L-157 CHARGER-9 CHARGER V8 C- 81 1948 8N FORD
I have a 8hp kohler that when it warms up starts to blow oil out of the breather is this a broken ring, or a valve problem? It seems to be buiding up pressure in the crankcase for some reason! thanks in advance! /forums/images/graemlins/confused.gif
   / kohler blowing oil #2
dp509,
That sounds like you called it right, a broken oil control ring.
It wouldn't take to much to check it. Piston and rings shouldn't cost too much.
Chad
   / kohler blowing oil #3
The crankcase breather may be incorrectly installed or defective. I can't remember how it is but they will do this if the breather is not right.
   / kohler blowing oil #4
Ditto on the crankcase breather....If it is malfunctioning your crankcase loses the vacuum it creates to keep the oil in. In most cases they are just gummed up.
   / kohler blowing oil #5
My 12 horse Kohler was blowing oil, and the problem was the crankcase breather. The breather on mine is a metal box with spring loaded valve in it. The box also has a drain hole in it. A previous owner had removed the breather and put it back in with the drain hole up. The breather would fill with oil and couldn't drain. /forums/images/graemlins/tongue.gif
   / kohler blowing oil #6
Thats it gspig, I could not remember up or down. You got it.
Sharpsburg huh, I live just east of Winchester. Howdy.
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2025 Mower King SSBM72 (A50123)
2025 Mower King...
