Oil & Fuel Kohler 30KW standby generator
   / Kohler 30KW standby generator #51
Guardian must be cabbaging parts from Kohler. My 17KW vapor fired Guardian V twin has the exact same cooler pictured in your PDF file. It holds 2.5 quarts with the oversize oil filter and it still uses oil but as I stated previously, all engines use oil and I suspect it gets pretty warm in the enclosure anyway.
Our standby is primarily for my wife's contentment, not mine. If I had my druthers, I'd have a Caterpillar or Onan diesel powered standby unit, skid mounted in the shop that would run everything plus the neighbors.
I much prefer diesel exhaust over propane.....:)
Having a genset that smells like a forklift running leaves something to be desired......
   / Kohler 30KW standby generator #52
I am considering a 30KW home standby generator. I have eliminated Generac and Kohler from my list because they both use a lightweight overhead cam GM engine with a timing belt running at 3600 RPM. I will not buy a GM overhead cam timing belt engine. Instead, I am considering generators using the old cast iron GM 3.0L engine that runs at 1800 RPM.
Bill
   / Kohler 30KW standby generator #53
....I've eliminated GM-Government Motors from my vocabulary entirely the whole caboodle.
   / Kohler 30KW standby generator #54
Bill
That's interesting, any other specs, brands, links???
JB
   / Kohler 30KW standby generator #55
200 Gallon Tank (A57148)
200 Gallon Tank...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
Truck Mounted Carpet Cleaning Extraction Machine (A57453)
Truck Mounted...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2008 CAT 305C (A53317)
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
