Kohler 10 Hp. Carb problems
/ Kohler 10 Hp. Carb problems #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
I have a Kohler K241 10 hp. on my Lincoln welder. It has a fixed jet. The only adjustment screw is for the idle mixture. Ever since it was new (about 15 years ago), the motor will hesitate when throttled up from an idle. Sometimes, the motor will sputter and die. Other times it will come right up to speed. I don't use the welder a lot and I drain the gas when it sits for a long period. I've tried gumout and carb cleaner with no results. Any ideas on a fix?
Daryl
Forage Services L.P.
/ Kohler 10 Hp. Carb problems #2
Have you tried taking out the jet and cleaning it? They will some times get partially clogged and you have to remove and
clean,be carefull not to damage.
213089 (A64276)
213089 (A64276)
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
CASE TV450B Compact Track Loader (A65053)
CASE TV450B...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
