knocking starter on 5105
/ knocking starter on 5105 #1
daRedbone
Prairieville, La.
John Deere 5105
I turn the key and get some quick knocks coming from starter area before the starter begins to turn engine over. Number of knocks varies but 5 or less. I suspect solenoid but thought I'd check here before throwing parts at it.
It just passed through my little mind as I started it a few minutes ago, it may be the battery. I'm accustomed to a constant almost buzzing sound in vehicles and they never turn over after they do that. I'm still thinking solenoid though.
/ knocking starter on 5105 #3
Could be any reason, the solenoid would be my last guess.
Check battery, charge and load test, check battery cables and ground wires. You might find one or more issues in that area.
/ knocking starter on 5105 #4
I would check the starter to see if it is loose. If the starter is not loose, I would then check the flywheel to see if it is loose or missing teeth.
/ knocking starter on 5105 #5
Is your tractor running again? What did you find?
Stout Buckets HD72-3 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
(10) New CATERPILLAR Keys (A65579)
(10) New...
