Knock in Diesel Engine
/ Knock in Diesel Engine #1
lee roy ball
1955 powermaster Ford diesel
I Would like buy 1955 Ford Diesel Tractor. Has solid knock in engine as if hitting tin. How can i check this with out pulling the complete engine? The Crankshaft Pully seems to be off balance, but tight and secure.
Thank You!:confused2:
/ Knock in Diesel Engine #2
I know nothing of a 1955 ford diesel. That said, most harmonic balancers are mounted on the crankshaft pulley via rubber between them. Being that old the rubber my have deterated hence your pulley wobel and a likely source of the noise you hear. The good news is shouldn't be too bad to fix.
/ Knock in Diesel Engine #4
Don't know what the sumps are made of on those but if they are steel it could have a dent in it with the crank hitting it. I have had this experience with a car.
If you put your hand on the sump with the motor running you could feel it hitting.
Doug
Generator (A61572)
Generator (A61572)
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2023 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2023 Posi Track...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
1985 MRK BOAT 2011 HMDE TRAILER (A61574)
1985 MRK BOAT 2011...
