KMW 214 Loader seals question
/ KMW 214 Loader seals question #1
owner66
KMW 415 Loader seals question
Hi, long time listener, first time caller.
edit: actually its a 415, just noticed my messup
I bought (stole at $1900) a Simplicity 9518/5015 a while ago with a 415 loader.
Need to rebuild the seals in the cylinders, they are shot.
I looked at getting the parts manual for the loader, but have not had a lot of luck cross-referencing parts on the tractor itself, so thought I would ask here first.
I need to find the seals.
Did the KMW loader come as an option on anything else?
I've seen a mahindra 214 loader, are they the same?
The loader I have has 1" rod, 1.5" cylinder.
There was a piece of plastic material between the 2 rubber seals on the one with the dimensions. One of those seals is flat, the may or may not be.
Here are some pics:
/ KMW 214 Loader seals question #2
My suggestion would be to take the cyl to a hyd shop and have them measure and sell you a kit or parts and you do the repair if you are so inclined.
Probably save a lot of time.
Any idea what I would be looking at as far as cost per cylinder?
I like to walk into a place kind of knowing what to expect.
Also the cylinders are stamped:
KMW Canada 1036
F-04
290383
/ KMW 214 Loader seals question #5
The seal kits could vary in price depending on factory parts, to 3ed party source, to individual o-rings, etc.
If the local hyd shop can not order them, they should be able to come up with something similar, and maybe even better. Good luck.
