KMW 214 Loader seals question
   / KMW 214 Loader seals question #1
owner66
KMW 415 Loader seals question
Hi, long time listener, first time caller.
edit: actually its a 415, just noticed my messup
I bought (stole at $1900) a Simplicity 9518/5015 a while ago with a 415 loader.
Need to rebuild the seals in the cylinders, they are shot.
I looked at getting the parts manual for the loader, but have not had a lot of luck cross-referencing parts on the tractor itself, so thought I would ask here first.
I need to find the seals.
Did the KMW loader come as an option on anything else?
I've seen a mahindra 214 loader, are they the same?
The loader I have has 1" rod, 1.5" cylinder.
There was a piece of plastic material between the 2 rubber seals on the one with the dimensions. One of those seals is flat, the may or may not be.
Here are some pics:
   / KMW 214 Loader seals question #2
My suggestion would be to take the cyl to a hyd shop and have them measure and sell you a kit or parts and you do the repair if you are so inclined.
Probably save a lot of time.
Any idea what I would be looking at as far as cost per cylinder?
I like to walk into a place kind of knowing what to expect.
Also the cylinders are stamped:
KMW Canada 1036
F-04
290383
   / KMW 214 Loader seals question #5
The seal kits could vary in price depending on factory parts, to 3ed party source, to individual o-rings, etc.
If the local hyd shop can not order them, they should be able to come up with something similar, and maybe even better. Good luck.
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
