Mowing KM2560 Mower Deck
/ KM2560 Mower Deck #1
Pondjumper
Spicer, Mn
2016 Kioti CK 2510H
Anyone that has the newer Kioti KM2560 mower deck having leveling issues, left to right? When I set the height adjustment rod for example to 3.5 inches, the left side (side with the adjustment rod) will be close, but the right side will drop another inch plus causing a "stepped" mowing appearance. I have tried adjusting the j bolt on the opposite side to try and compensate. Only way I can get it to cut right is to drop the deck to the stop (height adjustment rod) and the then raise the deck till the deck is level by appearance only, not very user friendly. Is that just the way these mowers are?
/ KM2560 Mower Deck #2
I have the same tractor with the same problem. Our CK2510 was delivered with the km2560 mounted. The deck was not level front to back which we fixed but I cannot determine how to cure the right side low issue. In addition the deck is not high enough to engage the transport lock. Has anyone else had this problem and fixed it? What did you do?
/ KM2560 Mower Deck #3
I just got the same tractor and mine, too, does the same thing. Did you get any help resolving this?
/ KM2560 Mower Deck #4
Still no resolution on the deck. Have you heard anything?
/ KM2560 Mower Deck #5
If you just got it, you might consider taking it back to the dealer to have them fix it. It's likely more than a few folks have had the same issue, and it's been reported to Kioti corporate. The techs there should have the fix by now....if a fix is available.
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2022 EZ-GO ELITE...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
KUBOTA KX057-5 EXCAVATOR (A65053)
KUBOTA KX057-5...
