kl4010 loader lift capacity
/ kl4010 loader lift capacity #1
jmh1783
Darlington, PA
Mahindra 2555 HST
I'm looking at a ck3510 or ck4010 both have the same loader. The lift capacity at the pins is 1835 lbs. I can't seem to find a spec for 24 inches. What I'm trying to figure out is will that loader lift a pallet of between 1200 and 1400 lbs using pallet forks off the back of a truck? It is not something I will be doing often, but it is a deal breaker for me. Any experience would be appreciated.
/ kl4010 loader lift capacity #2
http://www.********************.com/articles/Loader-Specification.aspx
Using this write-up as a reference I calculate that you're going to be barely able to lift the 1200# (70% of 1835# is 1284#)
To reach 1400# at "bucket center" you're looking for a pin capacity of at least 2000# and that's dead on. For some "breathing room" I'd look for closer to 2300# at the pins to get you a little over 1600# (1600# calculates out to 2286# at the pins)
Hope that helps, I haven't been a real engineer since college.
Thanks N2DFire. It has been too many years since college physics for me.
/ kl4010 loader lift capacity #4
Not to muddy the waters but here's a few thoughts.
Will you be using forks off the bucket itself or drop the bucket and use forks directly? If so that will make a significant difference to the lifting capacity. (and if you're going to use the forks a lot I'd strongly recommend not using them off the bucket - I do both and can tell you it's much nicer not using them off the bucket. not just load capacity but maneuverability, safety.)
Also, when you lift a pallet off a truck consider how high off the ground the deck is? Then consider at what height the max capacity of the loader is rated at. (I haven't looked it up for the loader in question.)
And also consider that when you go to lift the pallet you can roll back the pallet a bit and that will actually put a small portion of the weight behind the pins which will allow the loader to lift a little bit more weight.
Also consider all the other tasks you'll use the tractor for - I've no idea what you'll be using it for but for myself while there's times I'd like to be able to lift a bit more with my forks for everything else I wouldn't want a bigger tractor for my property - and there's been times I've given serious thought to that very question and at the end of the day I always come back to the fact that it's the perfect size and larger would be more of a hindrance.
Hopefully some one who has the loader in question can demonstrate a known weight being lifted because that will give you a real world answer. I can tell you my tractor (Ck20s rated to lift around 1100lbs at the pins) can easily pick up a 55gallon steel drum full of concrete on a pallet. Math says that's conservatively over 800lbs. So that's roughly 73% of the rated capacity. (and given how easily it lifts it I know it'll lift more. I've maxed out it's lifting capacity so I know how it handles when it's at the max.)
73% of 1835lbs is 1340lbs. So while this is all conjecture my guess is you'd be able to do it. Like I said hopefully some one can prove me right/wrong.
To sum up consider the bigger picture and what you'll use the tractor for. Would a bigger tractor be helpful for all tasks? Then go bigger and you won't have to even think about it, and it's sure nice not operating at the max capacity. If you're trying to save money by not buying bigger then hopefully some one will give you a real world test.
Hope that helps.
E.
Everhard: I will be using SS forks not bucket bolt ons. I have been debating on tractor size. Smaller has some advantages. Im not sure if I have good enough reasons to go bigger. Thanks for your help
/ kl4010 loader lift capacity #6
For those still searching the internet for this answer:
In this video a man claims to have loaded 1520lbs worth of red oak at Toyota Tacoma truck bed height.
Of course properly ballasted with about 800lbs in the rear.
/ kl4010 loader lift capacity #7
Lol poor Tacoma! But that aside great real world demo. You could see when he had it lifted where there 4 foot width was across the forks the loader was working but well in it's limits for the height raised, and could easily go a fair bit higher. When he switched it so the 4 foot length was in line with the forks it was definitely starting to get closer to maxed out - which he then verified at the end of the video when he says it wouldn't have got it much above the top of the sides of the bed.
Shows the difference of having all that extra weight further out from the pins.
Still given the claimed rating at the pins if that was my tractor I'd be happy with that capability.
E.
/ kl4010 loader lift capacity #8
Has anyone tried lifting a pallet of wood pellets with their CK? More accurately, can it do a controlled descent from a pickup with it? I have a backhoe or wood chipper for a heavy ballast…
/ kl4010 loader lift capacity #9
No one has ever attempted to lift a pallet of wood pellets from their truck bed?
/ kl4010 loader lift capacity #10
If the loader has the capacity to lift it even an inch off the truck bed then it can be lowered in a controlled manner assuming the operator knows how to feather the controls lightly.
Also depending how close to the limits of the loader you're at when moving pallets - if you can tilt the pallet back a bit safely without the load on the pallet coming off then you will gain lift capacity. This can make the difference between not being able to lift the pallet even an inch off the truck bed to lifting it a few inches.
Do you know how much a pallet of wood pellets weighs?
E.
/ kl4010 loader lift capacity #13
I mean, that's just obvious. No, for a loader rated at 1835 lbs lifting capacity at the pins (not to full height, either), you shouldn't plan on safely lifting 2000 lbs of pellets (plus the pallet weight) using an SSQA fork attachment out ~24" in front of the pins.
That said, it would be close to capable. Just pull 8 or 10 bags off the top of the pallet real quick by hand, then you're good to go.
/ kl4010 loader lift capacity #14
Around here the pellet/energy log producers shrink wrap the pallet and on energy logs also strap them.
I would not want to haul ours with the pallet partially broken down, pallet loses its rigidity.
jmo get a tractor that can lift more than 1800lb at pin to full height
/ kl4010 loader lift capacity #15
jmo get a tractor that can lift more than 1800lb at pin to full height.
I needed a machine to load full pallets of lumber. Having to unstack a few pieces wouldn’t be the end of the world but when you cut the straps the rest of it is flying everywhere so that’s really not a solid option.
/ kl4010 loader lift capacity #16
I buy 1.5 tons per year, so not much. I’m going to have tractor supply pull 13 bags off two separate pallets and hit the top with a quick pass of the shrink wrap. That’ll put me close enough to where I need to be with the 315lb pallet forks.
Thanks for the replies!
…and I messed up the thread title. It’s a 4030 loader, but still essentially the same deal.
/ kl4010 loader lift capacity #17
Just to close it out—the tractor with 3000lb cap Tarter brand pallet forks was able to lift 37 bags off the trailer. I had the pto chipper on the 3pt. Having the backhoe on may’ve been a bit better.
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
