Loader KL401 loader tilt cylinder specs
/ KL401 loader tilt cylinder specs #1
Weeeee
Elton, WI
Kioti DK 40SE HST
I bent the rods on the tilt cylinders and need to get them repaired or replaced. The Kioti parts/cylinders are expensive, but I can't imagine the they are that unique and could not be replaced by some aftermarket options.
Anyone know the specs on the tilt cylinders for the KL 401 loader on a 2014 DK40SE HST? Dimensions etc.
I would look at mine but the tractor is currently 300 miles away and I am looking for alternatives.
/ KL401 loader tilt cylinder specs #2
Based on similar posts I have seen, no other good options available. Most went with new rods and seals to fix them.
Let me guess back dragging with them all the way extended?
/ KL401 loader tilt cylinder specs #3
If you are replacing both cylinders, it is far less complicated. Find a cylinder with the same rod in rod out lengths, same pin hole size, similar fitting location, similar diameters and away you go.
If i can get back to the shop in a reasonable time, Ill take some measurements for you.
I am not sure if back dragging was the cause as I was pushing tons of snow with the bucket and the tilt cylinders almost fully extended. Possibly a big mistake?
I also run a grapple and move large logs and boulders all the time so it is possible this was a cumulative problem. My dealer wants about $1300 for 2 new cylinders but I am hoping that I can find a cheaper solution. Either repair at a local Hydraulic shop or replace with an aftermarket cylinder.
I will probably head up to my cabin this weekend where my tractor is, and pull the cylinders and bring them home with me. I just wish I knew exactly when and where I bent them so I don't do something stupid again.
