KL130 on a CK30 Problem
/ KL130 on a CK30 Problem #41
shvl73 said:
If I am remembering correctly, Dick B. at Batchelders in Lebanon Maine did just that for a customer. I think the guy's statement was essentially that it appeared as new after he was done. I guess it would depend on the skill level of the welder doing the repair.
Yes, a good welder should be able to make a near perfect repair. However, the structural weakness would still exist so further cracking at the same point could be anticipated. I don't know if Batchelders also reinforced the corners somehow but just welding the cracks would not solve the problem long term.
Also, RexB, thanks for pointing out the the "B" model designation was only on the name plate and not on the bigger decal on the loader arms. My earlier post was ambiguous.
For what it's worth, I have also heard from a little bird, that there now appear to be problems with some of the KL120 repair kits. Apparently not all KL120 loaders were built with exactly the same dimensions and for some loaders the repair kit interferes with, i.e hits, the brush guard. Kioti subcontracts these loaders and apparently was unaware of the various model changes. Given that they are getting the repair kits from the original manufacturer, it appears the builder doesn't keep very good records either. Too bad, it is a fine loader otherwise.
/ KL130 on a CK30 Problem #42
My patience is running thin. It's time for the fix for the kL130 to come out!
/ KL130 on a CK30 Problem #43
I can only guess that he did, as I believe he's a certified welder. I do know he used to make short track car frames. That was quite some time ago.
/ KL130 on a CK30 Problem #44
If they can cut the back half off of a car and weld a new one on with no visible evidence then they can certainly repair a cracked loader. It can be done right. It can also be done wrong, very wrong.
/ KL130 on a CK30 Problem #45
Jeez, I had no idea. Would you care to elaborate?:D Maybe just post a link to your photos for the newbies.
/ KL130 on a CK30 Problem #46
Woot! Fireworks!!
popcorn...beer...scorecard...
:p
/ KL130 on a CK30 Problem #47
No need to elaborate me thinks. The posters in this thread have hundreds or thousands of posts so can search for themselves. Bottom line is be very very careful about who you let weld on your tractor. Be very very sure you know what the plan is, and by all means, if buying new, get the new B series loader.
/ KL130 on a CK30 Problem #48
RexB said:
Hi PA hayseed, iso IslandTractor's good info, here is a pic of the new "B" model FEL arm and how the torque-tube penetrates both sides of both arms with welded steel plates on both sides. On the FEL the barcode label will read "KL130B Loader", tho the "B" is not on the larger "KL130" stencil on the loader arm.
click n zoom
Happy tractor-hunting, and did you get it yet? We love Pics :)
Sorry for the late reply, I was on vacation last week and have been pricing tractors, loaders, trailers, and new trucks. Think the new truck thing will have to wait awhile. I'm kinda settling on the DK35 HST but not sure 100%, if the DK40 is only a couple of more dollars, I rather have the horsepower/capabilities for future toys er um implements. The dealer is supposed to come up my way to appraise my current tractor then we get down to numbers. I'm thinking that the original quote he gave me is a little high, but that may be because they give book on trade ins/ups.
I have outgrown my 28hp tractor and need something with a bigger FEL that also lifts higher, and has more umph in all areas. The 28 was nice for grass, but was lackluster in all the other chores. Besides, the draft control on the DK made me all tingly inside. Planning on growing something next year, I made contacts this year, and some local contractors may pay for my saturday mornings (and help offset the cost of a bigger tractor) and the trailer needed to haul it. Man those DK's sure are heavy.
Since I know I may be asked, I primarily use my current tractor for cutting grass (8 acres), garden work, snow clearing, and land clearing leveling/prep work. It also has been used as a ladder, furnace and oil tank remover, cheap amusement for my daughter, general lifting for 6x6's and creosote logs, ground breaking (new soil), shale moving and gravel moving, and topsoil pile maintenance. The FEL is never taken off, it gets used everytime it comes out of the garage. I want to upgrade for the small farming I plan on doing, mainly tomatoes and some melons on about 4 acres. I also plan on doing some excavating as my house is going to be moved next year and I will need a new basement and sewer/water/electrical lines buried. Plus I got some land clearing work lined up if I get the bigger tractor, brush hog stuff mainly w/stumps and rocks.
Wow this is too long. Sorry. you'll probably see me posting in the attachments section pretty soon.
/ KL130 on a CK30 Problem #49
When choosing between the 35 and 40 DKs be sure to compare the loader specs. I recall one of them being much more powerful.
/ KL130 on a CK30 Problem #50
Thanks for the info. i would love to get a DK45, but I'm squeezing as much into my budget as possible. The weight of the tractor with FEL and loaded tires, as previously posted about in multiple other threads, requires me to buy a bigger trailer than I had planned on. I am also thinking about going with a woods FEL, as they seem more capable than the kioti ones. And as everyone on this board knows, as you upgrade little items the cost compounds. Of course if money wasn't an issue i'd probably own a 45 with a cab, sure would be nice in the winter. Never moved snow before when I was warm. I've always either shoveled, snowblowed, or used the rear blade and FEL to move it.
Of course if the dealer is willing to really negotiate, maybe a 45 isn't out of the realm of possibility.:D
/ KL130 on a CK30 Problem #51
Joe is correct. The KL351 loader for the DK35se lifts about 1400lbs at pivot pins. The KL401 for the DK40se and DK45se lifts a bit over 2700lbs at pivot pins.
There is not that much difference in price between the DK35se and DK40se and about two grand from the DK40se to the DK45se.
For my purposes the sweet spot was the DK40se with KL401. Only 10 hours in the seat so far but only good things to say. I'll post in more detail soon.
/ KL130 on a CK30 Problem #52
In regards to the woods loaders, i noticed woods now has curved arm loaders for some of the smaller compacts as well now.. A nice fit for the ck35 and dk35 would be the new Woods LC 102, max lift is 1650 lbs to the pivot point... These loaders would make a perfect match for these tractors in my opinion.. You can see them now on the Woods webpage...
/ KL130 on a CK30 Problem #53
So Island... Whats it like having almost 3 times the lift capacity of your old machine... :) How do you like the DK40? Matt
/ KL130 on a CK30 Problem #57
:D :D :D :D :D :D :D
Once I can wipe the grin off my face I'll start writing to describe the new DK40. I am also very impressed with the Caroni TM1900 flail mower.
/ KL130 on a CK30 Problem #58
/ KL130 on a CK30 Problem #59
Holy Heavy Load IslandTractor, that's a heckuva hunk of concrete it's carrying, niiice machine.
/ KL130 on a CK30 Problem #60
When I went to play..er .. um I mean test drive the DK35, it had the KL351 and another tractor had a new Woods FEl on it. It wasn't quite the apples to apples comparison I was hoping to see, as a DK and CK are different. It may have been more of a red delicious vs. a granny comparison. The dealership stated that a primary reason fro people choosing the woods over the KL351 was that the woods is QA and the KL351 is just a FEL. I went to the Woods home page and did not see it advertised that way, with alternate implements.
Am I wrong in this assumption, that QA should mean disconnect one attachment and attach another. Because if it is just about removal of the unit, it seems like a worthless option. Now the specs between the two loaders are different, and to me that is primary choice between the two (if of course Kioti and Woods are doing their spec sheets the same way).
