KL1210
/ KL1210 #1
RobRN
Maine
LB 1914 2002
I just bought a 2002 Kioti LB1914 and it came with a front end loader (KL1210) !! I am super excited! Love this toy! I have bucket trouble though...Wondering if anyone has a manual or knows where I can get one for the loader/joystick. I cannot get the bucket to stay in position when trying to back drag. Thanks. ROB robrn2000@msn.com
/ KL1210 #2
Are you pushing the lever up into the float position? If you are the bucket will float with the terrain and may not work so well if you're back dragging.
/ KL1210
I guess that is my problem...I don't know what the different positions of the joystick are.
/ KL1210 #4
Push it up just enough to put the bucket edge where you want it. Don't push up too far or you'll feel it "click" past the detent. That just put it into "float". It will follow the surface then.
/ KL1210 #5
I've got the same tractor and loader and I've found that it is difficult to get the bucket to stay exactly where you want it while dragging. It takes some experimenting with lever pressure. I'm pretty sure this is just the way these loaders work.
/ KL1210 #6
You could be experiencing a little bit of cavitation also. I know this loader is somewhat prone to that. One thing that can help is to keep tha RPM's going pretty good.
More RPM's = MORE gallons per minute = less cavitaion
2024 Texoma 16ft. T/A Equipment Trailer (A68183)
2024 Texoma 16ft...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
CAT 953 4-in-1 Bucket (A68134)
CAT 953 4-in-1...
2017 Ford Transit 150 Cargo Van (A66736)
2017 Ford Transit...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
