KL120 FEL only lifting up 1 foot...
   / KL120 FEL only lifting up 1 foot... #1
Dmace
Elite Member
Wakefield, NH
Kioti CK20 HST
Well, I finally had my first problem with the CK20. I had been working all morning (5 hrs or so) backblading the driveway and moving some top soil. I shut her down to go in for lunch (1/2 hr) and when I went back to working with the tractor, I noticed the loader will only lift off of the ground about 1' and then stop. I still have full use of the curling action and it still has good lifting capacity for that first 1'.
I am stumped... /forums/images/graemlins/confused.gif
Any ideas ?
   / KL120 FEL only lifting up 1 foot... #2
You should probably call your dealer first,
yeah, yeah, I know, we're closed /forums/images/graemlins/grin.gif
If you don't get it figured out here, give us a call Monday morn
Becky
I called you guys today at 3:00 pm right after I found out. It would be nice to have your hours on the website or at least on the answer machine.
   / KL120 FEL only lifting up 1 foot... #4
Does it seem to stop hard at the one foot mark or just sort of slow down and stop? To troubleshoot, try swapping hoses at the QD's. If problem is gone then the curl should be bad. If its still the same, something wrong with the cylinder(s) or possibly something mechanical. Does float still work? If so can you put it in the float position and jack it up somehow past the one foot mark to see if something is jamming in a cylinder or binding elsewhere. Just a few thoughts that pass my pea brain.
Steve
</font><font color="blue" class="small">( Does it seem to stop hard at the one foot mark or just sort of slow down and stop? )</font>
It stops rather slowly just like it's hitting a relief valve or something.
</font><font color="blue" class="small">( To troubleshoot, try swapping hoses at the QD's. If problem is gone then the curl should be bad. If its still the same, something wrong with the cylinder(s) or possibly something mechanical.)</font>
That's a good idea, I think I will try that. I did just hook up the backhoe today, but I doubt that had anything to do with it.
</font><font color="blue" class="small">( Does float still work? If so can you put it in the float position and jack it up somehow past the one foot mark to see if something is jamming in a cylinder or binding elsewhere. Just a few thoughts that pass my pea brain.
Steve )</font>
The float position still works fine. Tomorrow I will try and jack it up in the float position. I will also take a video to post.
Thanks for your help !
   / KL120 FEL only lifting up 1 foot... #6
We're always here 8:00am to 5:pm during the week.
8:00-12:00 on Saturdays
or as long as there are people coming in.
When the days get longer, we're here from sun up to sun down. And sometimes Sundays.
When I update the website next week, I'll post the hours
Give a call Monday if your still having a problem, but I'll let Eric know anyway.
Becky
   / KL120 FEL only lifting up 1 foot... #7
Did the problem start right after you installed the backhoe? when the loader lifts, 2 things happen, oil is pumped inot one side of the cylinder and returned out the other. you might double check all your quick connects and make sure they are fully connected. Might be 1 foot is how far it will move before the pressure builds on the back side of the cylinders to the point of kicking in thePR valve...
I installed the backhoe early in the morning about 7am and this didn't start until about 2pm or so. The backhoe still works great, I spent the rest of the afternoon digging up some stumps I needed out of the way.
   / KL120 FEL only lifting up 1 foot... #9
Just some shots in the dark, but make sure your diverter valve is all the way in the 3:00 position, and that all the quick attaches are connected solidly.
Make sure there is nothing, like limb or something, blocking the loader from coming up all the way.
Start the tractor, lift the loader all the way it will go, curl and roll back a couple of times and then power it down to the ground.
If that doesn't work, try turning off the diverter valve, start the tractor just for a few seconds, then turn the diverter back again to 3:00 position and try the loader again.
John
   / KL120 FEL only lifting up 1 foot... #10
Check hydro fluid level? Maybe the backhoe hogged too much.
Even disconnect the BH and see if it works again.
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
LOT LOCATIONS (A51222)
Heavy Haul trailer (A49461)
Heavy Haul trailer...
2013 John Deere 824K (A51039)
2013 John Deere...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
