KL120 FEL only lifting up 1 foot...
   / KL120 FEL only lifting up 1 foot...
I checked the hydraulic fluid and it was half way between the two lines on the dipstick. I assume this is the safe area. The bucket curls and dumps perfect, fast and powerful. I can put the bucket on the ground and dump it, it will pick the front of the tractor right off the ground. It has to be something with one of the cylinders for the lifting of the FEL. I can't see any other solution... /forums/images/graemlins/confused.gif
There goes a perfect weekend of yard work down the drain. /forums/images/graemlins/mad.gif
   / KL120 FEL only lifting up 1 foot... #12
Dmace, your low on hydrofluid, fill it up to the top line and try cycling the loader...
Thanks, I hope that works.
   / KL120 FEL only lifting up 1 foot... #14
</font><font color="blue" class="small">( There goes a perfect weekend of yard work down the drain. /forums/images/graemlins/mad.gif )</font>
I'm sure the boy's at b's will fix you right up.
It was too muddy to do any work here.
Jim
   / KL120 FEL only lifting up 1 foot... #15
Talked to Eric this morning, doesn't believe the fluid is low, he'll be giving you a call shortly.
   / KL120 FEL only lifting up 1 foot... #16
Someone mentioned back pressure on the side of the cylinder that should be returning fluid to the system causing the fel to stall at the 1 foot height. Based on your symptoms, that's also what occured to me. One possibility is a broken linkage or pivot screw in the hyd valve assembly, allow the high pressure fluid to flow, but not opening up the low pressure exhaust side enough. But, my guess is a hose quick connect for the fel that's not competely seated for that end of the cylinder.
   / KL120 FEL only lifting up 1 foot... #17
Derek
Don't panic when you get home if your tractors gone. /forums/images/graemlins/shocked.gif
Eric just left to pick it up.
50 hour service and fix the loader.
Becky
Sweet!
I can't wait to get her back.
I must say that is the fastest service I have ever received on anything I have ever purchased.
Thanks again Batchelder Sales !
   / KL120 FEL only lifting up 1 foot... #19
Derek
Your tractors fixed, nothing major.
Had Eric not forgotten the oil wrench, he would have serviced your tractor at your house.
You'll have her back tomorrow.
   / KL120 FEL only lifting up 1 foot... #20
</font><font color="blue" class="small">( Your tractors fixed, nothing major. )</font>
Inquiring minds want to know.
What was the problem?
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
