KL-120 loader specs. CK-20
   / KL-120 loader specs. CK-20 #1
cptdave
New Hampshire
Kioti CK-20,Wheelhorse 4-14-8
The KL-120 operators manual states the loader has a lift capacity of 770 lbs, and a tipping weight of 991lbs. The Kioti web page states the KL-120 loader has a lift capacity of 1074 lbs. Any thoughts?
Cpt.dave
   / KL-120 loader specs. CK-20 #2
The 770lbs. is an unballasted lift rating (nothing on the 3 pt.) the 1074lb capacity is with ballast on the 3 pt.
   / KL-120 loader specs. CK-20 #3
Go to Kioti buying. I posted an attachment there. /forums/images/graemlins/smile.gif
   / KL-120 loader specs. CK-20 #4
Gerard, are you referring to the picture of your new CK20? Otherwise, please let us know which thread you are referring to. Thanks, John
   / KL-120 loader specs. CK-20 #5
Sorry John. I should've been more specific. I posted a copy of the spec sheet that my dealer gave me. It has ALL of the loaders specs and the thread is "Kioti FEL - KL 102 Questions" in Kioti Buying/Pricing.
   / KL-120 loader specs. CK-20 #6
</font><font color="blue" class="small">( The 770lbs. is an unballasted lift rating (nothing on the 3 pt.) the 1074lb capacity is with ballast on the 3 pt. )</font>
Jon, I'm not conviced they have the rate right yet. I had contacted them about several changes that should be made and I guess the engineers gave those figures, but I don't think I could lift 1074 under any circumstances. I'm not sure how much less the lift would be with forks, but I couldn't lift 810 pounds (two 55 gal. drums of diesel). I had to move one off the pallet and put it on another pallet and lift them separately. I realize forks change the rate, but that much? John
   / KL-120 loader specs. CK-20 #7
<font color="blue"> but I don't think I could lift 1074 under any circumstances. </font>
1074 lbs. is "@ the Pivot pins"(with ballast on the 3 point). Looking at the New Holland specs....they lose 31% moving 19.7" forward, which would be near the front edge of the bucket. Using this formula, your looking in the neighborhood of 741 lbs. near the front edge of your bucket. Now add upto 36" in front of that for your pallet forks....
You'll also need to subtract the weight of the pallet forks and the weight of your toothbar (if applicable).
Don
   / KL-120 loader specs. CK-20 #8
Thanks Don. I couldn't have said it better myself. /forums/images/graemlins/grin.gif
   / KL-120 loader specs. CK-20 #9
</font><font color="blue" class="small">( Now add upto 36" in front of that for your pallet forks.... )</font> Thanks Don. I was aware that the rating was from the pivots, but I sure didn't realize it dropped so rapidly. All things considered, forks, toothbar and approx. 410# for one metal drum of diesel I was lifting about 600 pounds after separating the two drums, and may have been able to go a little more weight, but not much. John
   / KL-120 loader specs. CK-20 #10
its no differant than picking up a 5 gall bucket of oil at your feet, or setting that same bucket of oil on a table in front of you, at arms length, and try to lift that. Big differance in lifting the same weight..
   / KL-120 loader specs. CK-20 #11
</font><font color="blue" class="small">( its no differant than picking up a 5 gall bucket of oil at your feet, or setting that same bucket of oil on a table in front of you, at arms length, and try to lift that. Big differance in lifting the same weight.. )</font>
You're right about that Virgil. It made a big difference but as long as I only put one full drum on the pallet, I have no problem getting it out of the truck. John
   / KL-120 loader specs. CK-20 #12
I am quite impressed with your real world experience.
I think that is very good.
KO
   / KL-120 loader specs. CK-20 #13
</font><font color="blue" class="small">( I am quite impressed with your real world experience.
I think that is very good.)</font>
Thanks for saying that Kiohio. Sometimes I wonder if I should post "every little thing," and then I remember that there are a lot of people out there with no experience at all, and if it helps even one, I'm glad I post. John
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
Dodge Charger (A56859)
2016 Deere 180G (A60462)
2016 Deere 180G...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
