KK Disc Report
/ KK Disc Report #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
So...I finally had a chance to hook up my new King Kutter 5 1/2' Box Frame Disc this past week....and I thought I would report on its operation using a light tractor like my 790.
First off...they guy I buy from has his KK stuff painted red...so dont let the looks fool you....it's KK. This disc is pretty stout. After picking it up at the dealer, I had to adjust the cutting angle of the Disc....which was a PITA as allt he bolts had to be loosened to get the gangs to slide...and I didnt have many tools out in the field. I got that done and gave it a pull.
On my trial run...the disc was a bit light and would only penetrate about three inches.....I kinda figured that may be the case....so I put about 150 #s of log on the frame for weight and gave it another try. Much better.
The disc pulled pretty good on the first pass through virgin soils (sandy loam)....getting about 5" or more penetration. But, on subsequent passes....with the same (aggressive) setting the tractor would spin-out at times until I lifted the disc a bit to help it along...even in 4wd with the diff locked. I need to try another less aggressive setting or take some weight off for the second pass.
My 790 has fluid in the tires and I left the loader on for front ballast. The tractor picked up the disc fine...so I may try to add a bit of weight for the first pass operations....but it wont help with subsequent passes.....I just lack traction in this soil.
/ KK Disc Report #2
I think you're having trouble cause of the sandy soil. I think if you were in clay like we have down here you'd fair better. Good luck and let us know what you figure out :p
Troy
/ KK Disc Report #3
"but it wont help with subsequent passes.....I just lack traction in this soil...."
Just an aside, but that's one problem with many of the sub/compact tractors produced today........they certainly posess the engine power and drive train to use an implement but they don't necessarily have the weight and heft to do it completely. Not criticizing your tractor at all, just making a general observation. I use a nice, medium built 5' disc carrying some extra weight with our 8n/NAA and rarely if ever find the tractors having a problem with it in our soil conditions ranging from sand to dry clay.
/ KK Disc Report #4
I second what phyxer says. I have ran into sandy mixed type soil pulling good on the first pass and darn near stuck like feelings from there on out. Weight helps on the first trip but hinders from there. By changing the angle of the gangs to not so aggressive or a less agressive implement will help more than anything. On the bigger tractors we use duals on the rear tires, flotation is key. Duals on a 790...... That would look cool. Maneuverability/fit-ability would suffer due to added width. Nice lookn 790 by the way.......
/ KK Disc Report #5
Tough looking disc foggy. The bright red paint looks good also. :)
Couple weeks ago I found a like new (faded paint) 6 ft. angle iron framed disc on CL for $495. I had already picked up a Cosmo 500 3pt spreader on CL for $300 that the previous owner had used only once.
Bought both pieces of equipment because a few acres of our pasture are blowing thanks to a drilling company not replanting grass when they were finished.
It was calm last weekend so we spread a mix of bluestem grass seed then lightly disced the area to cover it. The spreader and disc worked great. We had no trouble with the angle iron frame so I guess it was money well spent.
/ KK Disc Report #6
I don't know how my MX5000 would do with a disc but I can't help thinking about all the time I spent as a kid on a Allis WD 45. It pulled an 8' disc all day long whithout ever having a traction problem. Gearing and weight are the keys to ground engagement tasks.
/ KK Disc Report
Heres another pic of this disc. I really like the build quality...this disc should hold up pretty well....and it's easy to stack weight on it. I was not too happy with the amount of work it took to change the angle of the front and rear gangs....and this was one of the big features I had anticipated. :mad: I figured it would be easy to remove one bolt (at the center) and slide adjust the front and rear gangs to the degree of cut wanted. But nooo......I had to loosen up a buncha bolts to free things up to get the gangs to pivot. Anybody else with one of these, that has a tip on getting it adjusted??? :confused: Maybe its just all the fresh paint? :confused:
On second thought....much of my wrench bending had to do with the gangs being set wrong which would not allow the clearance to adjust for the most agressive setting (the U bolts were too close to the frame). Plus I did not have the best tools with me. With this now corrected (the gang setting)....it should not be that big of a deal.
/ KK Disc Report #8
It funny how our 4WD scrappy tractors can't pull what the lesser 2WD tractors did when I was growing up. I spent many days in the seat of a Allis WD45 pulling and 8-10' disc all day long. Its all about weight and gearing for ground engagement tasks.
Not sure what your JD weighs but the WD45 was:
The bare tractor weighed 3,955 pounds, with 1,900 pounds of weight being added to each rear wheel
/ KK Disc Report #9
Foggy, be sure your disk is not cutting so deep the axle is in the dirt or even pushing dirt. That is possible on sandy soil and will really load you down. If you want the depth you are getting now, worst case remove outside blades all around. Depending on how close you are traction wise the outside ones on the front axle are easy to remove and may be enough. Agree with your thoughts you will find next adjustments easier.
/ KK Disc Report #10
Foggy, one other thought. Don't disk the field all the way across one time and then come back to it for second pass. Rather over lap your cuts. For each pass be disking 50% of disk (width) is on first pass and 50% on second pass. We have some sandy soil which this works in but slipped my mind as I have not put disk in that field in few years. You might give up a little depth on this. Also you may find the you can run across what you have disk the first time at a 45 or 90 angle to work better for traction.
/ KK Disc Report
Thanks for the advice Ken. I like the idea of taking on part of the load on the next pass...that may work out good. I also will try a second pass at an angle to the first. :)
The tractor and disc combination does a pretty good job on the first pass....it's the second pass (when I've got the soil loosened up) that becomes the traction issue. If it wont work out for a second pass....I have a drag harrow and / or a tiller to get the soil into shape. I am hoping though that changing the angle on the disc will allow some cutting and mixing of my soil / trash.
/ KK Disc Report #12
Foggy,
I have a KK 51/2' and went through the same loosening of everything to change the angle. I haven't changed it since then. I found that I had to have a longer top link than the one which came on my Kubota B7800 in order to get penetration on the rear discs. I like the log for weight, and think I will add one to mine.:)
/ KK Disc Report #13
Have had for several years a KK 6.5 angle frame disk pulled behind my TC30 with Hydrostactic tranny . Were I live in Southern Oregon is a clay type soil that with moisture , can be worked pretty good . Without moisture , use the backhoe instead .:(
First thing I fixed was the arms from the top of the top link connection to the back of the frame . These were bolted on thus limiting the amount of adjustment that could be made to back axles . They are now instead welded to the inside of the frame , thus freeing up more space to be less agressive on back axles .
Second was weight . First added a 4' piece of 3" x 12" x 3/8" I-beam welded on top and at back of frame . On top of that I placed a old 40 gallon galvanized water tank . Depending on moisture content in soil , I run it from 1/2 full to topped off , ( like it is now ) .
Third was axle spacing / design . Was not impressed with results when confined to a single pass area , ( going between a tree and fence for example ) . Sure can turn around and go back through , but regardless of angle settings on front or back , Front being cupped out , would always throw more out than back would pull in , thus either leaving a trough in middle , with hills on both sides . Or trench's down both sides through the middle of the hills on the outside .
First tried reversing the blades on front from cupped out to cupped in . But as with the boxed frame , the angle of front axle is wrong , ( to cup in , the axle needs to be angled back from center like picture shows in original post of the back axle ) .
So then added 4" x 8" x 1/2" steel to tops of the axle mounting brackets changing angle of axle's to angle back from center . Was going to drill additional holes to bolt solid , but since it was working great in both virgin passes as well as additional passes , just welded in place .
A problem during that process was that front axles were to close initially in center , ( was using smaller steel ) , which caused build-up between axles , thus I used the larger , longer steel pieces .
Next problem with that though was center would not get disk in those single pass areas . Added and welded 2 pieces of 4" x 3/8" steel from bottom of top link connection down past front of frame with holes drilled high and low and inserted a 16" ripper from Agri Supply , ( used in box blades ) .
When needed for those single pass areas , I drop the ripper and proceed . Tears up the middle ground pretty good and after the disk passes completely by , it looks like just the disk came through with no trough down middle . Areas were ripper is not needed since I can over lap passes , I raise ripper and pin in place .
Those pieces of steel are also welded to front of frame providing more support .
Were I was piling soil up against fence line , is now working its way back to a level surface .
Terrain : UGH !! Here is were it gets ugly . Worst grade is 12.7 % , That's from the high point in Northeast corner to low point in Southwest corner . Going downhill , SWEET !! Going uphill , Better have weight in FEL bucket to keep front axle with traction , especially after each pass . All I am doing is making fire breaks down south and west side's of property , and keeping the weeds from growing on both sides of our right-a-way for driveway . Driveway is not bad , as it flattens out about half way down .
But returning back up past that half way mark , need weight in front end .
Speed also makes a huge difference in how a disk finishes soil . For initial passes , I am in low range . Finish passes , I go up to middle range . Soil then lays out flatter . My brother who still farms here , has the hired help run the same way with a 16' disk behind a challenger .
Someday I will find my camera cord to connect to my computer , ( which has disappeared into a deep hole some were ) , thus be able to post pictures again . Course , could just buy a new cord , but then would find other and have 2 then .:rolleyes:
Take Care ,
Fred H.
/ KK Disc Report #14
On the disk I built I did not use bolts for the center bolt you have to remove for adjustment, I used pins and lock nuts for the bolts that attach to the gang arms so the gangs would freely move when I pull the pins for adjustment.
Here is the link showing pictures.
http://www.tractorbynet.com/forums/build-yourself/81139-finally-finished-disk-harrow.html
/ KK Disc Report
Thanks for the post Wushaw....and nice build on your disc!
I had seen where some competing models used pins in lieu of the bolts....as found on my King Kutter. I looked at mine and considered putting pins in place of the bolts when I was adjusting my disc......but I thought the bolt was needed to prevent the center section from "riding up" on the frame. I will definitely look at it again when I get near my disc....as it would be nice to make quick changes in the disc settings via pins instead of bolts.
You have the same number of blades as I do on the KK and a similar size tractor....how does your tractor pull your disc on the most agressive setting? Also, in thinking about my situation....I may back off on the rear blade setting and leave the front set to dig more. I need to play with it more to figure out the best way to set it up for my tractor. I'm glad I didn't buy any wider disc or more blades....as I originally had considered. This disc will provide all the excavation size I want.....at least in my soils. :)
/ KK Disc Report #16
I guess it has to do with weight and soil conditions. I have a Jinma 254/284. The tractor weighs 3,800# then the loader is another 800# plus I have loaded rears for a total weight of 5,200# and it has pulled my 6' Ford Disc no problem along with my King Kutter 2 Bottom Plow. I have also used my neighbors 11', I believe, no 3 point draw bar pull disc.
These are not my tractor but just like it minus the FEL and he does not have the rears filled. He is a guy on another site I am on and he posted some vids of him doing some plowing and disc work with his Jinma 28 Hp 4x4 tractor. He is pulling a old 2 bottom plow then a 12' disc with ease.
YouTube - Jinma 284 Doing Fall Plowing
YouTube - Jinma 284 and 12 Foot Disk Harrow
Chris
/ KK Disc Report
Chris
There is a substantial difference in how this Jinma is "pulling a disc" and what I am trying to accomplish. I likely could pull that disc across a field like that Jinma is doing too....it looks more like my cultipacker than a disc the way he's using it. He is just breaking up clumps and the gangs are not set very aggressive and the discs are not penetrating very deep. There is no weight on that disc and in viewing the video...he is not moving much soil.
What I am trying to do is more of a primary tillage task. When I am operating the King Kutter with an aggressive settting the blades are digging about 5" into the soils....almost up to the hubs.....and doing some tillage....and doing it though sod in sandy soils....much different scenario IMHO.
/ KK Disc Report #18
It can be interesting pulling it, The disk weighs 630lbs and is 5', I had to rework it after that initial built and it is Ford blue now. It pulls it and does the job.
Adjusting the gangs is easy with the pins, I made sure things had good cleareances for movment.
/ KK Disc Report
Today I pulled the KK 5.5' disc again. I removed the log I had for weight and reduced the angle of the cut by one notch. This seems to be the combination for me and my tractor...and my soils. I was able to cut almost to the disc's hubs on the first pass and I did not bog down on subsequent passes. I think I was needlessly heavy and set a bit too aggressively on the previous outing. It seemed to work pretty nice all day with this setting......not too agressive and not too whimpy. I was able to till some rocky ground and get about 1.5 acres ready for planting. I think I will leave the disc set up as it is. Changing the angle of the disc gangs took a couple of crecent wrenches....the use of a hammer and...in a few minutes it was good to go.
I still like the my tiller as my first choice....and would select it first.....if not for the rocks and stumps I am operating around in this situation. I think the disc takes a litte longer than the tiller....but with the trashy ground I am currently working....the disc seems to be the answer.
Today we also put down a couple of tons of lime and incorperated the lime into the soil with the disc. Also opened up a new trail and smoothed it out with the disc.....followed by my wife with the four wheeler and a flexible drag. Pretty slick. I think I have the hardest working wife the world has ever known (and she's just a little bitty thing)....what a girl. :)
/ KK Disc Report #20
You probably would be better not using as much weight or no weight and just making more passes,disking down to where you want,takes many passes,its a disk,not a plow or rototiller.
Plus you got to maybe adjust it so's its not as agressive,gotta work with the tools you have,or buy new tools.
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
(11) HAND SANITIZER STATIONS (A60736)
(11) HAND...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2018 Freightliner M2 106 20ft Reefer Box Truck (A60352)
2018 Freightliner...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
