KK brush hog
/ KK brush hog #1
dclymer
Granite Falls NC
N.H. tc21
I too have a KK brush hog that I had lift height problems with.
I lowered the pins by 4.5 inch's and also installed a adjustable lift arm on the other side as well this gave me more adjustment latitude . It solved my problem with the hog as well as giving me more adjustment with other atachments as well. Dee
/ KK brush hog #2
Dee, from what I've read here it's a design flaw. I believe a lot of folks have solved it by expanding lower bolt holes to the proper size and using those. I'm sure if you use the search feature here you'll find it talked to death in some other posts. I hope this helps.
/ KK brush hog #3
I hate to risk giving the wrong information about a competitors product, but since no one from KK has addressed this point, I will try to clear something up. Many times, designers of rotary cutters have difficulty keeping the PTO from coming into contact with the front of the deck when the cutter is fully raised. In addition, the liability of having spinning blades at a height where they may come into contact with humans is not desireable. Placing the lift pins a height such as KK uses, minimizes these problems and makes a very useable implement.
If you feel the need to lower your lift pins you might keep these criteria in mind. If someone from KK reads this and feels I am all wet, please feel free to correct me, as I would hate to misrepresent the facts, especially in someone elses product.
/ KK brush hog #4
Hmmmmm "makes a very useable implement"----nope----with most small compacts the KK pin placement results in a very UNuseable implement. It is a design flaw,actually, more likely it is "it's worked that way for a hundred years so why change now mentality" . J
/ KK brush hog #5
You bring up a good point, Jim. I have a Howse 6' rotary cutter on my JD 950. It raises the cutter so high, the PTO shaft hits the front edge of the cutter deck. The first time I did it, my adjustable top link had backed off a little and I raised the cutter and didn't realize it was hitting until I looked back and saw the deck had partially shredded the plastic protective PTO shaft cover. /w3tcompact/icons/frown.gif The second time I did it, well I just wasn't paying attention. /w3tcompact/icons/blush.gif With the top link properly adjusted the cutter leaves the ground well before it hits the shaft, so I just have to watch what I am doing.
/ KK brush hog #6
I have seen the discussion on the pins and compacts with the KK. Since I already purchased the cutter, and was waiting for the tractor to arrive, it had me a little concerned. While I haven't mounted the cutter yet, I did take a good look at the lift arms last night and took some measurements. From what I can see, I don't think I will have any problem. In the current installed position, I measured 17" from the ball to the ground, with it is set all the way down. This default postion looks like it it is closest to the highest position, but with the adjusting arms, and multiple holes in the lift arms, the level of adjustability seems great.
Would I be correct, that this issue is only with the smaller compacts? Did they shrink some of the dimensions down from the older cat 1 3pt specs? If so, KK should either come out with a line specificly for the smaller compacts, along with the older style, or come up with a cost effective way to handle both. Having the larger holes in the lower position, to swap pins, is probably a good start, but I am sure there are other things they could take the time and design in.
/ KK brush hog #7
John, the dimension that has been "shrunk" as you ask is the tire diameter. The smaller compacts have smaller tires which mean the unit sits lower and has a lower PTO output, a lower lift arms etc. The cutter pin location by KK and most other companies and many other 3-point implements are two high to operate correctly with the smaller tractors. I have no problems with my lowered pins with the PTO shaft hitting the cutter and I now get plenty of lift to raise it over obstacles. It would be nice to lower the top link also for easier adjustment but it is acceptable as it is now. J
/ KK brush hog #8
I use a 6' KK rotary cutter on a JD4700 with industrial tires and have no problems with the factory pin height on the mower.
/ KK brush hog #9
I got some good help on this very subject just a week or two ago. I put two new pins in the lower bolt holes (facing in) and now have no problem with it digging in when I cross my creek and start up the other side. Prior to that I had everything on the tractor (B7500) adjusted for maximum lift. The Bush Hog RFM never dug in because the pins are (guessing) about 4-6 in. lower than the KKs stock pins. It makes it nice for lowering it onto stuff you want to hog, also. Maybe manufacturers should start shipping the pins loose and giving us a couple sets of holes to choose from.
Fred
/ KK brush hog #10
I recently bought a KK 5 ft cutter. I have not had any problems with lift height or hook up using my NH 33D. I only wish i had some chain guards for it, they're on my to do list.
/ KK brush hog #11
I'm not trying to say that the KK design is ideal for sub-compacts, simply that there could be reason to place the pins at the point they have chosen. Actually, the KK design predates the sub-compact by quite a bit and I understand many TBNer's are very satisfied with their product. I also understand that KK now makes a cutter specifically for the sub-compact tractor. Perhaps this would be a better choice than their standard machine for your tractor. Without having access to one myself, maybe someone can comment on the XB KK series as to the pin locations.
I am glad this discussion has come up, with the release of the First Choice cutter line in the next couple of weeks, we feel we have learned from you all and will get it right the first time.
/ KK brush hog #12
Just look at the pic in my last post and see the top pins and then imagine how that would work with the tractor pictured, the B2410 is a little larger than a JD4100, 4010, 4110 and about the same size as the NHTC21. The XB unit you mention would work but it is slightly lighter duty than the KK standard cutters. No, I understand where you are coming from but the only reason KK places the pins where they do is because the same frame is used on all sizes of their cutters. Since smaller tractors sit lower due to smaller tires it is not possible to use the same pin height for all size tractors. KK should at the very least as suggested by another provide several choices in pin location to make their unit more "universal". I am hard headed Jim, sorry. J
/ KK brush hog #13
Yep, that can explain it. My tires are 9.5 X 24. I agree that subcompacts like this would need special linkage.
/ KK brush hog #14
As I am reluctant to criticize another company's product and wouldn't dream of speaking as to their motives, I can only say that First Choice has addressed this situation in our cutter line.
In addition, for those who wish to use a quick hitch with a sub-compact, we are developing a quick hitch which will hook up lower on the tractor side yet still fit Cat 1 spaced implements, including all First Choice ground engaging equipment. We have found the pin height issue presents similar problems with other implements in varying degrees, although it is mostly seen with cutters and post hole diggers, this may help the situation with "other" Cat 1 equipment in use with sub compacts.
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
213063 (A64276)
213063 (A64276)
John Deere 1025R (A62177)
John Deere 1025R...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
(2) Lights (A64119)
(2) Lights (A64119)
