Kitcheaide stand mixers
   / Kitcheaide stand mixers #31
I use ours twice a week to make a loaf of bread ( cups of flour) since 2002 when it was a Christmas gift to wife best of all. It works still the same - great - only some bolts had to be tightened.
The meat grinder we use for a year now, works great.
   / Kitcheaide stand mixers #32
I bought 2 used ones off ebay for less than $50.00 each. Mine still say Kitchen aAd by Hobart on them I believe. My wife likes to bake and had gone tru a handful of different mixers till I got these for her. I believe the older model have metal gears in them instead of plastic used now.
Wayne
   / Kitcheaide stand mixers #33
It looks like Kitchenaid has a lot of different SKU's .Some of them appear to be retailer exclusive. I think jdbower is right. Ive seen a large variation on the prices on similar Models (same wattage/capacity). There has to be a reason for these lower prices. It all cant be based on volume??? I have worked in the food industry, and can say that the KA bowl lift mixers are the standard when it comes to small mixers. Hobart is pretty well the standard in large mixers. Professional kitchens wouldn't still be buying KA if the quality wasnt there reputation or not. When you need a mixer, you need it if the unit doesnt work then you move on to one that will.
   / Kitcheaide stand mixers #34
My ex and I used to put up alot of veggies. We processed a lot of tomatoes to make and freeze various sauces with a Kitchen Aid mixer. The juice would find it's way into the front of the mixer and I would have to rebuild it on occasion but other than that, it was a workhorse.
   / Kitcheaide stand mixers #35
I ground an entire deer last year with my KA mixer and the grinder attachment. We added pork fat to get the right leanness. Cut into strips that barely fit the throat and as long as possible. Grinding is a low speed operation so the cooling fans are slower but it never got hot enough to stop us.
I ran the whole deer through the grinder twice to ensure a good grind and even mixing. Made for a store bought look and feel.
Every house I've lived in since I was born has been equipped with a KA stand mixer. Every holiday dinner we also break it out to whip cream for desert.
I also grind beef into burger since it is often cheaper to buy a roast than it is to buy ground meat and I know what's in a roast. We'll do 10lbs per batch this way and freeze it in one pound bags. My children know what cows look like, what a cow eats, where the roast comes from, and how that roast turns into burger, and how the burger cooks and tastes. Do your family a favor and be sure that they know how to make their food.
   / Kitcheaide stand mixers #36
Well, I missed out on the Amazon $69 deal so I opened the Costco KA I bought last weekend. In case anyone has a stripped synthetic worm gear (in use since the 30's apparently - obviously materials engineering has progressed significantly so we can hope that today's gears are better than the original), it can be replaced for the whopping sum of $10 and a bit of time with some hand tools. You can also buy a whole assembly and see the service manual here. I almost want mine to break so I have an excuse to take it apart :)
Edit: Note that there's a ton of conflicting information out there regarding the use of nylon components. My manual and box indicate "all-steel transmission" and one KA rep indicates that plastic gears are no longer used, other sources cite a nylon "disposable" gear in use since the 30's. Either way replacement parts aren't that pricey so I'm not too concerned.
   / Kitcheaide stand mixers #37
Hmm I quote the site
Kitchen Aid 4162897 Stand Mixer Worm Drive Gear Kitchen Aid - JUST $8.99 each when you buy 3
So you have to buy 3 and then I didn't even address shipping.
oh
$25.01 to $50.00 7.95
Point isn't is it cheap . the question why in the first place?
And hey if they are no longer used why??? Troubles??
   / Kitcheaide stand mixers #38
Check it out a bit closer and you'll find that they're $9.50 each there, to me $10 is cheap to get a $200+ mixer working again. Burn out the motor and you'll probably look at a much larger repair bill. Either way, it's the same way they've been built for over 75 years now so it's not like an older one will be any better in that respect.
   / Kitcheaide stand mixers #39
We have had one for about 12 years. Works great. No problems. It is the type that raises up out of the bowl with a lever, not the type that tilts back. It was more expensive than the tilt type.
I recently got the pasta attachment and it works flawlessly for sheets, fettucine and spaghetti.
I have had several consumer counter top meat grinders. None of them could handle any volume of venison unless the meat was already finely chopped and free of any tough bits.
It has been my impression that this Kitchenaide mixer would not be able to handle venison either but some of you guys have experienced otherwise. I've been meaning to buy a good commercial 3/4 hp grinder which runs over $300 but it might be worth giving the Kitchenaide grinder a try.
   / Kitcheaide stand mixers #40
I have processed 32 deer with my 24 yr old KA stand mixer. I'm still using the original grinding plate (plate with the holes" and original knife that I lightly honed sharpened many times. I use a very fine sand paper placed on a flat piece of glass and with a bit of water slide the knife in a circular /orbital fashion on both sides. As you have a very close tolerance between two blades of the scissor to assist good cutting the key to grinding is that the threaded plastic grinding plate holder (don't know what it is called) pretty tight. that causes very tight tolerance between cutter head and the grinding plate causing a good cutting action. I hardly ever have the meat in frozen condition to help grinding action. Need to use the tightening tool that comes with the grinder as it becomes difficult to open the grinder head up without the leverage it gives.
JC,
Niagara No. 46 Shear (A59213)
Niagara No. 46...
John Deere 6619 Power Unit (A57149)
John Deere 6619...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
2325 (A58376)
2325 (A58376)
2024 Yakta YXR610 Zero Turn Lawnmower (A57453)
2024 Yakta YXR610...
