Kioti Tractor Tuning
   / Kioti Tractor Tuning #71
A competent dealer will flag the serial number of any tractor that has had the fuel injection system or ECU tampered with and void any remaining powertrain or engine warranty.
Just something to think about.
   / Kioti Tractor Tuning #72
2610 has a completely different engine than the 3510/4010. Different displacement, fuel system, etc. Probably almost zero common parts.
It would still be nice to know if the 2610 could get juiced up to closer to 30 BHP. Or how easy it would be to tune the 35 HP 3510 to 40 BHP instead.
Ther is another thread on here where someone talks about changing the tuning on a 3510. It seems to be as easy as flashing new firmware into the electronics. It will void the warranty. it will also increase the fuel consumption.
   / Kioti Tractor Tuning #73
I did some quick searching and there are several cars using the Delphi DCM3.7 ECU. I looks like K-suite should be able to handle R/W and the check sum I believe the geletto can R/W but a few years ago they did not have the check sum corrected.
Alientech USA - K-Suite 3.16
I do not have my Kioti but should take delivery next week. I probably will not tune it right away but might look to see what it would take to connect to the ECU I have the equipment to connect to some of the older Delphi ECUs via OBDII.
   / Kioti Tractor Tuning #74
www alientech-usa com/index.php/latest-news/207-k-suite-3-16 (cant post links yet)
Which model are you getting?
BTW, welcome to the forum. :welcome:
   / Kioti Tractor Tuning #76
I'm getting the 3510 HST with FEL, grapple, backhoe and bush hog. I traded the Kubota L35 in it was a bit large and I got tired of fixing lines every time I started a project.
So why didn稚 you man up and get the 4010 from the beginning? It comes with a warranty that you won稚 be voiding by screwing with the calibration developed by the Kioti development engineers.
When you get into the controller, what training or skills do you have to know what, exactly, your hack is doing to peak firing pressure, pin bore stresses, valve bridge temperature, piston bowl edge thermal stresses, and a host of other sensitive engine design parameters.
Anyone can hack a calibration. Doesn稚 take much engine design knowledge.
   / Kioti Tractor Tuning #77
I did not go with the CK 4010 because I did not feel the price increase was worth the extra 2.5hp at the PTO.
What training do I have? No formal training I have read several books and done testing on remapping. I have personally tuned/remapped my own vehicles over the last 12yrs. When I worked on my GM3800 (gas) I did many fun things like add DFCO, 2nd gear start, adjusted timing in low load, add perimeters to move to SD mode in transient throttle positions among other things. In the diesel world I have only worked with the VW ALH motor where I added about 20hp smoothed out the power band added launch control and adjusted the variable turbo to reduce spool and prevent over boost. I also adjusted the EGR tables to aid in warm up, reduce it in high load areas adjusted the fuel injection timing tables to match the new profile. That was about 300k mi ago.
If I were to do any major tuning to the engine I would add a pyrometer to monitor temps and adjust accordingly.
Have you ever looked at the maps in an ECU? The exact same engine transmission and body can have 3-7 different revisions per year. The nice thing about tuning an engine is you can add in tables they left flat because they did not think it would be necessary to built. That often happens to the tables for Speed Density (using MAP and RPM) and this is fine most of the time but if you have a sensor like the MAF die you would be lucky if the engine will deliver any power.
   / Kioti Tractor Tuning #78
I am intimately familiar with engine calibration strategies and engine development. Saying you have experience because you hacked a few tables is sort of funny.
Try being responsible for development and release of complete engine families, including calibration, and living with the warranty consequences of getting it wrong.
Most backyard calibrator place some unwarranted faith in an exhaust pyrometer. Exhaust temperature tells you nothing about piston crown temperatures, peak firing pressures, pin bore loads, or valve bridge temperatures.
The only thing it gives you a clue about is whether the turbine blades will melt, or maybe if the exhaust manifold will crack.
   / Kioti Tractor Tuning #79
I did not go with the CK 4010 because I did not feel the price increase was worth the extra 2.5hp at the PTO.[snip]
Curious what price spread you were quoted between the CK 3510SE HST and the CK4010SE HST. A buddy is interested in both models, but hasn't checked pricing yet with dealers.
I don't recall if it was earlier in this or a different thread, but I recently saw a member say he was quoted $900 more.
   / Kioti Tractor Tuning #80
Finn; chilllll.....
Since you were clearly involved in engine calibration work, you would know that every engine released for production generally has quite a good safety factor baked in for various components. I can't think of an engine that I have measured/dyno'd over the last decade that couldn't easily handle 10% more power.
Add fuel to make a bit more power, and we know what will happen: Piston crown and bowl-rim temps go up, pinbore, conrod and main bearing loads go up, and probably exhaust valve and exhaust gas temps go up also (I almost typed out turbine also, but these are N/A Kioti engines). It's generally all direction-ally known. What we don't know, is how safe it will be over the long run. In cars and pickups, it usually doesn't matter too much since you can't really hold the engine at full load for more than 20-30 seconds max on any given road. On a tractor however, you could potentially get into trouble plowing fields, brush hogging tall weeds, etc. But if you only occasionally request max power from your machine, there's probably nothing inherently unsafe about eeking out 10-15% more HP for brief periods.
In any case, let people try some tuning and tinkering without admonishment. We can all learn from their mistakes or successes. It's not your problem, and they know it will be at their own risk. :D
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
49205 (A55788)
49205 (A55788)
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
