Kioti tractor data
   / Kioti tractor data #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
For you Kioti experts:
What is the problem with the Kioti factory website? All it has is a
"Find a Dealer in Your Area" applet. No links to tractor data like it
used to have. A couple of banner ads and a link for financing. It
has been this way for months. Fortunately some dealers have
posted their own info.
I would like to know:
> what is the weight of the CK35 HST? The brochure lists the
weight for the gear version only. I just found out that Kioti
quotes the CK30HST as 3329 lb in the owner's manual, but
3042 in the brochure and service manual. Quite a diff! What is
correct? Maybe someone has a CK35H owner's manual?
> for the DK35SE HST, the total hyd flow is specced at 15.2GPM.
Kioti does not quote the implement pump flow. It is prob in the
service manual as with the CK30. Anyone have a service manual
and can quote the implement pump flow?
   / Kioti tractor data #2
The site seems to be working for me. What browser are you using. The web site lists the CK30 HST Weight w/ Ag Tires w/ ROPS 3055 lbs. (1386kg)
The CK35 HST Weight w/ Ag Tires w/ ROPS 3,118 lbs. (1,414kg)
Sorry I don't have a manual for those, I own a CK25. But Kioti's web site seems to work for me. Hopefully some with those machines or a dealer can help out.
   / Kioti tractor data #3
It is confusing, always takes me a while to remember what to do.
Click on some of the stuff at the top, "Products" etc.
Mike
   / Kioti tractor data #4
Download and install firefox for your computer (works on Mac, Linux, Windows, anything). If you are using windoze, you're better off with Firefox as far as security goes.
Firefox - Rediscover the Web
To get the full experience of the site, you'll need the flashplayer plugin. When you visit the site with firefox, just click on the plugin installation (looks like a puzzle piece) and you'll get the nice animations the site has.
Firefox is an alternative to Internet Exploder for web browsing.
Interesting the Kioti site works for some others. It stopped
working for me about March I think. Large parts of the home
page have big boxes with small red 'x's in them. I suspected
it might have to do with my browser, but I am one of millions
using AOL 9. I can not even get to the old "products" tab.
I have also seen the 3055 weight listed for the CK30. I
wonder about the 3329 number, but it is clearly printed in the
owners manual. Now if we can only get our first CK35H owner
to post on TBN...... A DK35SE HST owner would be nice too.
Gravel13, what does your owners manual say about the weight of
your CK25?
   / Kioti tractor data #6
I've also had trouble at times with the Kioti (and other) websites while browsing with IE 6 or 7. Firefox has always worked though.
   / Kioti tractor data #7
dfkrug, you would have to ask. I've had my owners manual in one spot since I bought the tractor and then about a month ago my wife did some spring cleaning and i can't for the life of me find it. I'm leaving today for a little fishing trip and will be back on Sunday, I definitely find it then and let you know, or if I come across it while packing I'll post it.
   / Kioti tractor data #8
Let me add to the choir. When I started using IE 7, I had many wierd problems in lots of web sites. The Kioti site became unavailable. I switched to firefox and all of the problems went away. I'm a believer.
   / Kioti tractor data #9
I've used Firefox for mail and browser for the past 2 -2 1/2 years since I've been on TBN. There was a thread about it at or around the time I joined and I've been using it and have never had any problems like I did with IE no matter what version.
Steve
   / Kioti tractor data #10
I did a cut and paste. A bit rough, but most of it is there. And here is the link.
KIOTI HOMEPAGE
Engine
Engine Model 3A165LXB
Engine Gross Power 34 hp(25.4 kw)
Rated Speed 2,600 rpm
No. of Cylinder 4
Fuel Type
Aspiration
Displacement 100.5 cu.in. (1,647 cc)
Fuel Tank Capacity 7.9 gal (30L)
Pre-heating System
Transmission
Transmission Type
Shuttle Hydrostatic drive
Main Gear
No. of Travel Speed Forward/Reverse INF. 3
Min. Travel Speed of Forward w/ Ag1 @ Engine rated speed 0
Max. Travel Speed of Forward w/ Ag1 @ Engine rated speed 13.11 mph
Power Take-Off
PTO Type Live
PTO Power 26.5hp (19.8kw)
Rear PTO Speeds(1st) 540 rpm
Rear PTO Speeds(2nd)
Mid PTO Speeds 2,000 rpm(Optional)
Front PTO Speeds
Brakes and Clutch
Brakes Wet disk type
Clutch Dry single
Dimensions w/ AG Tire
Length w/ 3-point hitch 122.2 in. (3,103 mm)
Width 54.6 in. (1,387 mm)
Height from Top of ROPS 96.8 in. (2,460 mm)
Height from Top of ROPS Cab
Height from Top of ROPS Folded
From Top of the Highest Point
Wheelbase 66.1 in. (1,680 mm)
Ground Clearance 13.82 in. (351 mm)
Front Tread Ag Tires - Min 43.5 in. (1,105 mm)
Front Tread Ag Tires - Max
Rear Tread Ag Tires - Min 38.2 in. (970 mm)
Rear Tread Ag Tires - Max 51.3 in. (1,302 mm)
Turning Radius w/ Brake 9.5 ft (2.9 m)
Turning Radius w/o Brake
Hydraulics
Total Pump Flow 12.9 gpm (48.9L/min)
3-Point Hitch
Standard Category (Optional Category) Cat. I
Lift Capacity, 24" aft of hitch, lb(kg) 1,764 lb (800 kg)
Control Type
Weight
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
1706 (A54756)
1706 (A54756)
1721 (A54756)
1721 (A54756)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2007 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2007 GENIE...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
