Kioti Starting issue (ds3510 2014)
/ Kioti Starting issue (ds3510 2014) #1
MHSETRadTech
lufkin
Kioti ds3510
So my tractor was running fine, parked it and about a week later got on it and when I turn the key I get "one" click. This is what I've done so far.
replaced bad battery
replaced starter that was getting stuck
The result was still one click from the stop solenoid
I bled fuel lines but have not been able to get any fuel to come out the injector. I get fuel at the nut directly below the injector lines.
I bypassed the starter and all that happens is that the starter spins. At no point does the tractor actually try to start.
I took the oil fill port off and checked the pin that turns the injector gears and it moves freely.
Any advice as to what to do next?
/ Kioti Starting issue (ds3510 2014) #2
If the starter isn't spinning the engine, why are you messing with fuel lines?
Get the starter working so the engine spins and go from there. If you replaced the battery and the starter, then you have a wiring problem. Figure out exactly what the problem is and fix it. If the starter solenoid is clicking, but the starter doesn't turn or engage then the solenoid contacts are bad. Replace it.
I finally found it. It was the clutch safety. I bypassed that and it started right up
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
Hardee T-500-LP (A64126)
Hardee T-500-LP...
1901 T/A CAR HAULER TRAILER (A59914)
1901 T/A CAR...
2005 American Iron Horse Legend Motorcycle (A64127)
2005 American Iron...
Bulldozer Rake (A64127)
Bulldozer Rake...
AGroTK YC-32G (A64127)
