Kioti quick disconnect to change front impliments
/ Kioti quick disconnect to change front impliments #1
pasignman
Mercer,PA
MF 202
Hello, just askin if there's a kit to change manual locks on a quick change bobcat hookup, front high lift to change from bucket to forks using small cylinders to unlock and lock. Thanks.
/ Kioti quick disconnect to change front impliments #2
I've never heard of one being available, and I think someone would have mentioned it here if it was available.
I wonder if perhaps Bobcat has a patent on that system.
/ Kioti quick disconnect to change front impliments #3
I don't know of a kit to change the manual lock levers to a hydraulic lock setup. I could see where that would be handy if one has a disability, handicap or hard time operating the levers by hand. I'm also sure that even if there is no kit available a hydraulic device could be built that could serve that purpose.
As far as I know the Bobcat Advantage system is only available on Bobcat.
/ Kioti quick disconnect to change front impliments #4
/ Kioti quick disconnect to change front impliments #6
/ Kioti quick disconnect to change front impliments #8
A linear actuator works, and is cheaper than hydraulic.
A guy on here (one of my favorite threads) did it with a $60 actuator.
I designed my own (using a more expensive actuator), but haven't implemented it yet.
aaah, here it is:
http://www.tractorbynet.com/forums/customization/321704-linear-actuator-power-ssqa.html
My thread. :)
I'm still happy with it. My only problems have been with proper circuit protection (now resolved with a 10@ circuit breaker right next to the switch) & a bolt coming loose. Bushing came out & the connecting bar from the actuator got bent. I bent it back straight & tightened everything up. The bar has re-bent itself again a hair, but works fine so I can't be bothered to fix it again or do anything about it. Using a pipe or tube rather than a bar would give it more lateral stability, but be harder to fabricate ends for.
All in all I'd do it all the same as I did my 2nd version with the breaker if/when I ever get another tractor. I love it.
My first one used a $60 actuator that was not long enough), v2 used a $150ish actuator if I remember right. Actually now that I think about it if I built another I might just use the cheaper actuator only get the right length this time). Actuation speed is largely irrelevant I've found when you can just hit the switch when driving as long as its under 30 seconds or so.
/ Kioti quick disconnect to change front impliments #9
What are you going to use it on?
It was an option on Toolcats, think it is standard now. It is called Power Bob-Tach. You might be able to find the parts on eBay or call some Bobcat dealers. They also have a single cylinder version for skid steers.
/ Kioti quick disconnect to change front impliments #10
I'm just wondering why anyone would want to go to the trouble or expense of having that BobTach type system on a tractor. It's handy on a skid steer where getting out of the cab is a pain in the rear. But on a tractor, what does this system save you? 2 minutes max every time you change attachments on the FEL?
Maybe I'm missing something. Or, if I'm not, then I simply haven't become too lazy to get off the tractor to flip a lever (or two) to change FEL attachments.
Plus, if I'm changing to or from the grapple, I have to get off anyway to unhook the hydraulics from the grapple.
/ Kioti quick disconnect to change front impliments #11
I swap from bucket to forks to 3pt all the time. I don't have a grapple or any thing to hook up for hydraulics. As I use the forks as much as the bucket, its nice to be able to swap them in a few seconds without getting off.
Yes it doesn't save a ton of time, but it is really handy if you swap implements a lot, or are lazy.
I welded a cheap used 3pt quick hitch to a cheap SSQA plate a while back & have been really happy with that. My trailer mover is usually attached, but its great for moving or loading implements too. Knife maintenance on the flail is easy at proper working height when lifted on the loader (and braced with a post for safety if the hydraulics go).
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
S/A Solar Towable Speed Trailer (A64194)
S/A Solar Towable...
2014 IC Corporation PB105 School Bus (A64194)
2014 IC...
