Kioti parts...
/ Kioti parts... #1
patcopaul
Hi Folks,
Where is the best (cheapest) place to order good quality parts on-line for a Mechron? I prefer factroy parts.
Thanks
/ Kioti parts... #2
i have gotten them from my dealer but have not had to buy anything of consequince yet. What were you needing? Also i and my friend both noticed a bit of belt squeel this last weekend from our mechrons, and were a bit worried about that. I also saw the gator diesel for the military rated at 38 mph and it is a diesel with 2 speed much like ours. Wish mine went just a bit faster on a few occasions. I added a heater to mine last winter and it looks almost factory was about 250 bucks but went in fairly easy.
rick
/ Kioti parts...
Hi DrRick,
I don't need much, a couple of oil filters, bed rails for the dump bed and the rear screen for the roll cage. I can get them from my dealer for $400 or so but I was thinking about down the road, when somethig big breaks, assuming that it will.
My Mechron has proven to be very handy. I only have 13 acres and most of that is wooded but it was most helpful clearing trees after the hurricane we had last fall. We lost 4 big poplars, 1 maple and a sweet gum during that storm. The largest one went down and took the others out like dominoes. It cleared out a 200 yard path through the woods. Amazing! and t made a great shooting range. It took about 2 months to cut and split the wood but I have PLENTY of fire wood now. Too bad most of it is poplar.
The Mechron seems to be bullet proof (knock on wood). I haven't had any problems since I fixed the dragging emergency brake when I took delievery and I seem to find a use for it nearly every day. I've only put 50 hours on it in the 6 months that I've had it. I'm very happy with it.
I don't really have any opportunity to go any distance so the 25 mph that mine goes is plenty fast. I wish I had a large Nat'l Forset to run around in. That would be a blast and I could see a little more speed would be desirable there. The suspension on these things is great, lots of travel and a plush ride. As I said, Im very happy with mine.
Let me know what you find out about your belt.
/ Kioti parts... #4
DrRick... Can you add some details about the heater you added? I've got 65 hrs. on my Mechron and it's running just fine. I had the dealer do an engine oil change when he fixed the differential vents. That factory mod resulted in a gear lube change. I haven't needed any other parts or service.
/ Kioti parts... #5
Hi Folks,
Thanks
Since you posted this question twice I'll post my response twice :) I don't think you can buy Kioti parts online. Well... you can always find a dealer online and have parts shipped to you but I don't know of a "web store" where you can buy parts. If you find one let me know
/ Kioti parts... #6
Parts for all KIOTI equipment can be ordered on-line though our on-line parts cart.
/ Kioti parts... #7
i bought a universal type heater and i place it under the dash with a piece of strap holding it up ( under the hood is where i supported it ) i will get some pics as soon as i get back to ranch . It really looks factory and works pretty well . I used the line to the cig lighter for power. It has a 2 speed fan and is not obtrusive to the middle seat passenger. It suggested a simple t fitting into the radiator hoses, however I placed a t at the engine bypass outlet in order to get faster warmup. The pics will explain much more clearly.
/ Kioti parts... #8
Thanks. Please include mfg. and where sold. Do you have the cab enclosed?
/ Kioti parts... #9
Try your local dealer.coobie
/ Kioti parts... #10
utv parts and accessories dot com, i purchased the universal heater for around 250.00. I have a few pis=cs but cannot figure out how to upload.
/ Kioti parts... #11
i for the life of me cannot find anywhere on the web pages that indicates pictures
/ Kioti parts... #12
kioti 022.jpgkioti 027.jpgkioti 022.jpgkioti 027.jpghope this worked
/ Kioti parts... #13
another view
/ Kioti parts... #14
view of water line
/ Kioti parts... #16
How did you make out with your cvt belt .I have had my Mechron 2200 for about 3 months and my belt squeals some too. I opened it up and there is lots of slack in the belt and was wondering if anybody knew how much slack is normal
or how you would go about taking up some of that slack
I am 8 hours away from any dealers
any help would be appreciated
Mitch
/ Kioti parts... #17
I have a 2002 Kawasaki prairie 650 that's belt drive and now squeals AFTER replacing the belt (at idle) and likely putting it on too tight side of specs. On most belt drives there's selective thickness shims that go between the drive pulley sheaves that control installed tension. I have the manual for the Kawa but don't know on the Kioti.
Bobcat Turbo 873 Skid Steer (A62679)
Bobcat Turbo 873...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
429835 (A61166)
429835 (A61166)
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
