Kioti oil change that went wrong
   / Kioti oil change that went wrong
Do you have the link handy? I'd like to see that for myself. I'd still check with your selling dealer. I know my dealer pointed out to use the red cap filler on my DK-35 and DK-40 series Kioti's. I suppose it is possible there is something different about the CK-series, BUT why would the red cap be there if not for using for oil fill?
Thanks,
CM
As soon as i can find it i will post
   / Kioti oil change that went wrong #32
I second the air issue. The white smoke could be a sign of an air leak into the fuel system, not allowing the injectors to fire at the correct time (air is compressing in the lines. I'd double check your fuel filter bowl to make sure the seal is not kinked or compromised and is tight. Any dripping there when sitting? White smoke is incomplete combustion (usually) and can be a direct result of air in the system.
The oil fill on many engines (not familiar with Kiotis) is preferred at the timing cover as its a direct link to the crankcase. Its preferred only because it won't burp back due to filling faster than it drains, like the head. But it only takes another minute or two to drain down from the head. So either would be OK to fill. I think they add the two ports for convenience. My JD has the two, and the valve cover one is harder to fill from unless you prop the hood way up and not use a funnel.
   / Kioti oil change that went wrong #33
Unless your specific tractor CK-27 series requires that means of filling the crankcase, the way it is supposed to be done is through the red cap, NOT the valve/cam cover because of possible cavitation and air lock issues, where the oil doesn't always get down to the pan as it should.
I can't say absolutely, but I'm sure some other CK series owners can comment, or you can verify it with your dealer.
There is a good point being made by CM here, why else would there be the red cap fill point? That said and if there is an air lock and if coolant (being heavier than oil) is trapped there.... Would it not make sense to continue filling from the valve/cam cover in hopes of "displacing" the coolant as the oil rushes in? I assume it eventually has t drain down? Or can be checked with the dipstick. Then when all concerns are gone start using the red cap? Not sure how the cavitation comes into play.
   / Kioti oil change that went wrong #34
I remember reading some issues a while back were some owners pored the oil to fast into the valve cover and oil overflowed in the cover and got down the crankcase vent tube into the intake.
The tractors rapped real bad on start up do to the oil trying to hydro lock the engine and smoked real bad till the oil burned off.
If you fill the oil through the valve cover, pore slowly (or at least don't try poring as fast as it will come out of the bottle) or it could cause possible engine damage if it gets down the vent tube.
   / Kioti oil change that went wrong #35
That's IT! Thanks for remembering the details, DK35vince. The hydro lock was what I meant to say, not cavitation; (but I'm not real sure what if any difference there is between the two?).
Anyway, it seems the CK series red cap is smaller than the one on the DK series, maybe making it more prudent to fill oil from the valve cover than at the red cap. Though doing so may be easier, as DK35vince said, too much flow could cause problems with the oil's passing to the crankcase without restriction.
   / Kioti oil change that went wrong #36
I have the red/orange cap on my ct 225 (white ck 27) and my manual states to fill from it instead of valve cover. This may be the problem but I would change filter again and double check every thing there with the service manual ( spring, seal, air, any cracks ) just to be sure.
   / Kioti oil change that went wrong #37
Exactly what I've been driving at from the first post I made about this. I was not sure if it applied to the CK series because I've never seen how their oil fill ports are set up. Yours is obviously a Bobcat, (white version of Kioti).
There seems to be some confusion in the different manuals, workshop manuals, etc., but one thing is clear. Filling the crankcase at the lowest available port is best; second choice is at the valve cover, BUT slowly, so to not create a hydro lock event.
All very good and valid comments ! When i go back down next monday the first think i am doing is pulling both oil drain plugs and getting a small sample to see if there is any sign of antifreeze. If all is clean i will install a new clean filter and new oil. I will fill the oil at the red cap instead of the top valve cover. Someone at work today asked me if i filled the fuel bowl up before installing it. I did not fill bowl, make any difference ? The tractor started up ok. My farm tractor guys at work said to just keep operating the tractor for a couple of hrs and things should start to clear up....i have have only ran it for a half hour or so.
Here is the posting for the workshop manuals you can download. Go to post #40 for the link to download.
Kioti Workshop Manual CK25/27/30/35
Started by krazsk, 02-05-2011 07:26 PM
   / Kioti oil change that went wrong #40
Filling the fuel bowl can make for less cranking to purge air, but if the petcock is left in the off position then opened when the new filter is closed in the bowl it shouldn't take long cranking to suck fuel in and start the engine.
I wouldn't be overly worried about that, so long as there are no air leaks allowing air into the fuel system's pressurized side.
And running it may help clear things up.
You won't be able to 'see' coolant unless there is a fair amount of it present. I'd take a clean sample of crankcase oil and send it out for analysis. This will give you a reference point to work from. Oil analysis will give you PPM of whatever is in the oil.
Bucket (A55973)
Bucket (A55973)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A58017)
2012 INTERNATIONAL...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2014 DRAGON 130...
