Kioti oil change that went wrong
   / Kioti oil change that went wrong
How did you get antifreeze in your new oil jug again? Someone at your house added it? Why? By accident I hope?
I purchased a gallon jug of mobile 1 oil from Kmart one time and as I was checking out I noticed a small dirty spot near cap. As I looked closer I noticed the cap seal was broken. So. I then opened it to check inside in front of the employee and it was used oil. I'm not sure how this happened but employee said it was not the first time she encountered this. Some one is either returning for refund or a employee is making a big restock mistake of used oil return. Either way watch out when you buy your new oil.
It was by accident. I had thought that the seal was missing due to the person adding oil to the motorhome as i use the same oil. Never gave a thought about people returning oil for refund ...good tip !
Is there reason to worry about your other engines? Could he have contaminated other jugs of oil?
No worries about other engines. Just a accident and also me assuming that the seal was missing due to using some for the motorhome that uses the same brand of oil.
So after draining the oil again last night i let the engine set empty overnight. Went out this morning and removed the drain plug and saw no antifreeze coming out, just a few cups of oil. I changed the oil filter, no sign of antifreeze. Filled with new oil again and ran tractor for over a half hour, no faulty sounds ! Checked dip stick, clean. Engine still smokes but goes away after about 15 minutes of use. How long does it take to get the air out of the fuel system ?
I am back in Illinois for the week, so won't get to the tractor until next monday and tuesday.
Update from the beginning. When i did go to start the engine for the first time after draining the bad junk out, the engine made a clunk sound then started up. The second time i changed the oil and started the engine it started smoothly. I did prime the oil filter the second time as someone suggested he does this to help initial oil flow.
My concern is the white smoke i am getting. Starts out heavy then settles down to a lighter emission after engine is up to temp. but never totally goes away. From what i have researched, white smoke indicates raw fuel is not getting completely burned.I did change the fuel filter. I can hear the engine sputtering sometimes, like it is not getting fuel .
Anyway....it might be going to the dealer next week if i can't figure out something to check when i get back down there. Never had a diesel before....so thanks for letting me ramble !
   / Kioti oil change that went wrong #25
Where are you filling the engine with oil? At the valve/cam cover or at the red oil fill plug, near the injection pump on the side of the engine? It may differ on your model engine, I'm most familiar with the DK series...there may be differences.
I have a screw cap on top of the valve cover. Yes, i did see a red cap ( it wouldn't come off ) on the side by the injection pump, but the manual says to fill through the top of the valve cover.
   / Kioti oil change that went wrong #27
Unless your specific tractor CK-27 series requires that means of filling the crankcase, the way it is supposed to be done is through the red cap, NOT the valve/cam cover because of possible cavitation and air lock issues, where the oil doesn't always get down to the pan as it should.
I can't say absolutely, but I'm sure some other CK series owners can comment, or you can verify it with your dealer.
That being said, you could be seeing smoking because of the coolant and oil being poured through the top of the engine. I'd check the oil level cold to verify the crankcase is full. Then check it again after running it to temp and let it sit for at least 5-10 minutes, and verify level again. If you have to add more oil- do it through the red cap on the side of the engine, unless someone tells you different. Sometimes the manuals are WRONG, not surprisingly.
Don't feel bad, at least you're finding out about it sooner than later. :thumbsup:
Here's my thinking: Since the coolant and oil entered through the top of the engine the smoking is likely related to this process and may eventually dissipate on it's own. Same with whatever amount of coolant 'may be' somewhat trapped at the top of the engine.
Of course their may be air issues with your fuel filter change.
I'd want to verify the fuel bowl is completely sealed at the gasket, where the bowl meets the head unit. Also make sure there is a rubber gasket in place, and not missing. I don't move the lever at all, I just unscrew the bowl, insert the new filter, then crank the engine. You can put fuel in the bowl with the new filter to make for less cranking, but shouldn't have to.
Thanks so much for the reply ! I have drained the oil twice since i put the bad oil in. Have operated the tractor for 30 minutes after each oil change. After both times i check the dip stick before starting the engine and 10 minutes after engine shutdown, it has shown full with no antifreeze or off coloring showing. I did pull new fuel filter and the bowl was full. Both o-rings were present as well. I will call the dealer.
I downloaded the CK27,30,35 workshop manual. It says to fill oil from the valve cover port. No mention of the side oil filler port with red cap.
   / Kioti oil change that went wrong #30
Do you have the link handy? I'd like to see that for myself. I'd still check with your selling dealer. I know my dealer pointed out to use the red cap filler on my DK-35 and DK-40 series Kioti's. I suppose it is possible there is something different about the CK-series, BUT why would the red cap be there if not for using for oil fill?
Thanks,
CM
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
Case Backhoe (A55973)
2012 Bigtex Trailer (A55973)
2012 Bigtex...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
RoGator RG1100C (A55315)
RoGator RG1100C...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
