Kioti loader actual lift capacity
   / Kioti loader actual lift capacity #21
Actually that is the shipping frame that was around my WC68 6″ PTO Wood Chipper, PTO Wood Chipper - My next one will be a hardwood pallet with some 2x4 framing.
I have built some out of pallets and 2x3 framing - I sheathed them much like doing a fence so as to keep out the snow because they are for storage and use from during the heating season - I find they are just too bulky - besides the fact they easily susceptible to damage (as has happened during snow blowing around them!!) - I keep thinking the IPC crates would be the bomb - but they sell around here for approx 100 bucks (plus). Tks
   / Kioti loader actual lift capacity #22
^ Yeah IBC totes all the way. They are typically pretty expensive by me too. Finally found a guy with a yard full of them ~40 miles away who was willing to keep the soiled plastic liners, and just sell me the cages for $25 apiece, so I got at many as would fit on my trailer. I wish that had been more than 12, but it's a good start. Now I just need a stronger tractor so that I can actually fill them up all the way (can be over 1500 lbs with wet wood).
Hello fellow NB'er. I purchased a 1000 litre IBC tote for $125 from a local dairy farmer and I am using it to collect rain water. He also gave me a couple of damaged ones where the containers were punctured so my average cost went down. The containers cut in half on a pallet make great wheelless barrows.
   / Kioti loader actual lift capacity #24
We have different loaders...mine is KL6010....but it's a beast! KL5510 loader is pretty close on spec sheet at least so it seems like you should be able to handle that. With filled rears & and a 6' box blade on back can still lift rear wheels before loader runs out of @$$. Moving IBC totes full of water on pallet forks.....I can pick up and move around a 275 gal which is ~2400 lbs total + weight of SSQA forks. I can't get a full 330 gal tote & either pump some water out or only fill to ~300gal. So around 2600lbs is what I can at least get off the ground & high enough to drive around & out on pallet forks, I think that's pretty good. Same for getting off a trailer - I struggle but can get a 275 up & off the trailer, a 330gal, I can't.
The Kioti loader not as smooth as Kubota (esp dump+curl together), not as strong as LS, but the combination of smoothness, capacity, and overall height I think makes it the #1 or #2 loader available among all brands. The loader primarily sold me on the NX since i need the real high dump clearance AND the strength to get a bucket of clay soil that high with ease.
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
