KiotI LK3054 Operator's Manual
   / KiotI LK3054 Operator's Manual #23
Morning.
Well I came across this post after I purchased a LK3054 Kioti.
I would really like an operators manual as well. Can I pay you for a copy..
I've got a Paypal account..
I know the spirit of this forum is to share, but I've been looking for this manual and I would compensate you for your time in sending me
a copy of the PDF if you are still in possession of the file.
Denis Allan LeBlanc
Forest, Ontario
   / KiotI LK3054 Operator's Manual #25
I would appreciate (I hope I spelled that right) a copy of kioti pdf Thanks
   / KiotI LK3054 Operator's Manual #26
Could I get a copy of the PDF?
I have an oil leak and trying to figure out how to repair it.
It is very difficult to find any info on this tractor.
Any help would be appreciated.
Brad F.
   / KiotI LK3054 Operator's Manual #27
Brad F.
Where's the leak?
   / KiotI LK3054 Operator's Manual #28
I think about every drain plug is leaking oil.
Oil looks fresh
Just trying to learn more about the tractor.
   / KiotI LK3054 Operator's Manual #29
Have you replaced the washers under the drain plugs? They make some with a rubber (or some similar substance) center that helps seal better than the copper ones. 'Most any auto parts store should have them.
One of the oil drain plugs leaks a bit on mine too...looks like the previous owner cross-threaded it at some point.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2016 INTERNATIONAL WORKSTAR 7600 (A58214)
2016 INTERNATIONAL...
2827 (A58376)
2827 (A58376)
2013 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2013 MACK CHU613...
1981 FRUEHAUF CRUDE OIL TRAILER (A58214)
1981 FRUEHAUF...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
