Kioti lb1914 lubricants
   / Kioti lb1914 lubricants #1
jwillis8
I have recently acquired a 2000 Kioti lb1914 slightly used with no owners manual. I wondered if Kubota UDT hyraulic fluid would be adequate for both the hydraulics & the front axle and all gear lubes. It is supposed to be 84 viscosity. The front axle requires 80 weight gear lube ( recommended ). Thanks jwillis8
   / Kioti lb1914 lubricants #2
From the owners manual:
Front axle - Gear oil - SAE85W-90 or SAE 90
Transmission / Differential - Multigrade transmission fluid including:
Chevron - Tractor hydraulic fluid
Exxon - Torque fluid 56
Mobil - Mobil fluid 350
Pennzoil - Hydra-tranz and wet brake
Quakerstate - Tractor hydraulic
Shell - Donax T-4
Texaco - TDH oil
Union - Hydraulic/tractor fluid
Valvoline - Unitrac
   / Kioti lb1914 lubricants #3
You can use Hydraulic in the front axle also, your choice
BTI
   / Kioti lb1914 lubricants #4
Would a TO 30 oil work in the Trans/Hyd? I am using this in other tractors. Would help if i could us this in MY DK65C Kioti
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
