Kioti lb1914 lubricants
   / Kioti lb1914 lubricants #1
jwillis8
I have recently acquired a 2000 Kioti lb1914 slightly used with no owners manual. I wondered if Kubota UDT hyraulic fluid would be adequate for both the hydraulics & the front axle and all gear lubes. It is supposed to be 84 viscosity. The front axle requires 80 weight gear lube ( recommended ). Thanks jwillis8
   / Kioti lb1914 lubricants #2
From the owners manual:
Front axle - Gear oil - SAE85W-90 or SAE 90
Transmission / Differential - Multigrade transmission fluid including:
Chevron - Tractor hydraulic fluid
Exxon - Torque fluid 56
Mobil - Mobil fluid 350
Pennzoil - Hydra-tranz and wet brake
Quakerstate - Tractor hydraulic
Shell - Donax T-4
Texaco - TDH oil
Union - Hydraulic/tractor fluid
Valvoline - Unitrac
   / Kioti lb1914 lubricants #3
You can use Hydraulic in the front axle also, your choice
BTI
   / Kioti lb1914 lubricants #4
Would a TO 30 oil work in the Trans/Hyd? I am using this in other tractors. Would help if i could us this in MY DK65C Kioti
2012 Ram 5500 Service Truck, VIN # 3C7WDMDLXCG124340 (A51572)
2012 Ram 5500...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
UNUSED FUTURE GD47 47" LAND LEVELER (A51248)
UNUSED FUTURE GD47...
