Kioti lb1914 lubricants
   / Kioti lb1914 lubricants #1
jwillis8
I have recently acquired a 2000 Kioti lb1914 slightly used with no owners manual. I wondered if Kubota UDT hyraulic fluid would be adequate for both the hydraulics & the front axle and all gear lubes. It is supposed to be 84 viscosity. The front axle requires 80 weight gear lube ( recommended ). Thanks jwillis8
   / Kioti lb1914 lubricants #2
From the owners manual:
Front axle - Gear oil - SAE85W-90 or SAE 90
Transmission / Differential - Multigrade transmission fluid including:
Chevron - Tractor hydraulic fluid
Exxon - Torque fluid 56
Mobil - Mobil fluid 350
Pennzoil - Hydra-tranz and wet brake
Quakerstate - Tractor hydraulic
Shell - Donax T-4
Texaco - TDH oil
Union - Hydraulic/tractor fluid
Valvoline - Unitrac
   / Kioti lb1914 lubricants #3
You can use Hydraulic in the front axle also, your choice
BTI
   / Kioti lb1914 lubricants #4
Would a TO 30 oil work in the Trans/Hyd? I am using this in other tractors. Would help if i could us this in MY DK65C Kioti
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
