KIOTI KL4030 vs KL4030C loader?
   / KIOTI KL4030 vs KL4030C loader? #21
Not my letter, I have the KL 4030.
Copied and pasted from recall thread.
I got a letter from KIOTI today for this recall on my 2022 KL4030C loader:
"Please contact your selling dealer to schedule the installation of the upgraded Quick Attach parts"
Applies KL4030C loaders with serial Number Range:
US 210701596-220121311
CA 181101234-220120928
Applies KL4020 loaders with serial Number Range:
160919001-170811078
Applies KL2610 loaders with serial Number Range:
151120001-180211286
No details or warnings to stop using the current loader on your tractor.
   / KIOTI KL4030 vs KL4030C loader? #22
Thanks for passing on the recall info.
I asked my dealer about this and they are sending someone out to perform the recall in the field. Which is nice because I didn't want to take the tractor in.
   / KIOTI KL4030 vs KL4030C loader? #23
Wow, nice dealer.
   / KIOTI KL4030 vs KL4030C loader? #24
I got a response within minutes from Kioti on this, so that was cool. Here is what they said:
Thank you for contacting KIOTI. The KL4030 is manufactured by Sindong and the KL4030C is manufactured by Taesung. Sindong could not keep up with our demand on their own which is why Taesung is making the KL4030C. KIOTI considers these loaders interchangeable. Other than the slight differences in specs noted on the spec sheet. The lift capacity is slightly higher on the KL4030C, but the breakout force is a little less. The KL4030C does have a higher bucket rollback force at 2,758lbs. There should be basically very little to no noticeable difference in operation between the two loaders.
I think this response from Kioti is B.S. If a subcontractor can't meet demand you don't have another manufacturer make a different design, you provide the same blueprints to the new manufacturer to make the same loader. In addition these two loaders aren't interchangeable part by part only by the entire loader onto the tractor.
   / KIOTI KL4030 vs KL4030C loader? #25
Yeah I get what you are saying. I am guessing Taesung is Kioti's subcontractor for making the KL2610 FEL and were already tooled up for that and they worked a deal to build a beefier version of the KL2610 and call it a K4030C.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 LGMG SS1932E ELECTRIC SCISSOR LIFT (A60429)
2019 LGMG SS1932E...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
