Kioti Key
/ Kioti Key #21
scooter keys on ali expresss are a pretty close blank to the double sided orig,
/ Kioti Key #22
call your dealer on the phone and get a couple. they should be able to put them in a envelope and ship fairly reasonable.
you would have them by now.
/ Kioti Key #24
A pretty close blank is a poor substitute for a key that is cut and ready to use when purchased.
true, but it lets you butcher the top to make a mushroom style key that doesnt brake everytime you hit it with your leg getting on and off the tractor. besides i have access to a key cutter so its no biggie for me.
/ Kioti Key #25
Amazon sells Ilco 10 pack for about $10 + shipping. For the CK10 series the Ilco 1695 works and they're stronger than original Kioti keys. My original started developing a crack and it was only a matter of time until breakage.
/ Kioti Key #27
thats a nice looking setup
/ Kioti Key #28
I did this to deal with the bump-knee-against-key problem. Short piece of PVC pipe with a can lid glued to one end, the nut that holds the ignition switch also holds this in place. For sure they didn't really think key placement out very well when they designed this.
/ Kioti Key #29
While on the subject, these keys are easy to bump while going in/out and break easily. Next time I break one I will probably leave the indexed part in the switch and fabricate a protrusion on the front to toggle it since security is not an issue for me.
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
2015 Jeep Cherokee 4X4 SUV. (A66738)
2015 Jeep Cherokee...
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2009 INTERNATIONAL 7600 6X4 T/A  VACUUM TRUCK (A66091)
2009 INTERNATIONAL...
